Question about Presto 05420 FryDaddy Deep Fryer
My fry daddy wont heat up, is there some kind of fuse internal
I supplied 120VAC intead of 24VAC to my sanyo vcb-3424 camera and now it is not turning on. kindly tell me how to fix that problem?
Unfortunately by applying 120volts AC you probably fried your camera. Hopefully it could be an internal fuse but I doubt it.
Sorry Marty
Jul 15, 2014 | Cameras
Where can you buy drain daddy?
Drain Daddy was an item from QVC and is no longer available from them. Home Depot has a great liquid Hair and Grease Remover I recommend if you don't have a small electric drain cleaner.
Mar 29, 2014 | Drain Daddy Plumbing
What is the best kind of frying pan to use when making an omelette?
i recommend the Non-stick aluminum frying pan. it heats up really quickly and is easy to flip.
Apr 10, 2013 | Home
My frigidaire halogen top isflashing on the heat elements
there is a built inn overheating fuses to prevent the glass to overheat, this often happend when ther is using a not prober size frying pan, or the botton on it is not even, to start with try using a other frying pan to se if that help kind regards peter
Mar 19, 2013 | Cooktops
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
I need to purchase a fry baby
The fry baby is no longer manufactured. The smalles deep fryer is the fry daddy.
Aug 07, 2009 | Presto 05430 FryBaby Deep Fryer
It got dropped in orange!!
Neutralize the acidic orange juice(squash?). A bit of baking soda in a bowl of water in which you wash the mp3(stick) should neutralize the acid. Carefully dry the mp3 stick with towels and a cold flow of air from a fan or hair drier set to "no heat" should dry it out. Give it a try, what have you got to lose?
Jun 11, 2007 | Samsung YP-U2X Digital Media Player
Presto 05420 FryDaddy Deep Fryer Logo
94 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
ZenFire
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
