Question about Boating
15hp Evinrude, to start must hold throttle firm towards acceleration position to start, when starts won't idle until hot
  • 5,537 Answers
It sounds like your choke is not being used. If you are setting the choke, the carb is venting air somewhere. Take the cover off the motor and look at what is happening to the choke plate when you set the choke.
The choke plate should have either a vent on the butterfly plate if it closes tight or the butterfly plate should be ajar about the thickness of a credit card if the plate is unvented. Then check the mounting nuts on the carb base for tightness. If you want, you can put some ATV around the outside base of the carb to ensure its sealing.
Also note if there is a stepup cam for the choke RPM. This would increase the RPM with adjustment for cold starts and reduce the need to Throttle so much to cold start the engine. If it does not have this part thats Okay too, just a feature to be used if it is there.
Most likely your low speed idle mixture needs adjusting and its common to have the throttle capable of shutting off the engine without a killswitch. But try Cold starting it and see if sealing the carb base and adjusting the butterfly plate has helped. Then do the mixture adjustment if you are not happy with it.
If all this fails to help, have the engine running and try moving the throttle shaft with your fingers. You want to see if the throttle shaft has play where it pivots in the carb body. Its hard to explain but the extra venting of air can occur where the shaft rubs the casting. Depending on your talent it means you need a new carb or you need to rebuild the shaft.
Good luck on your motor.
Posted on Apr 23, 2010
Testimonial: "will give these a try thanks"
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
Starting proceedure for 72 evinrude outboard?
  • Check all connections , fuel, battery, etc
  • Squeeze primer bulb until firm
  • Lift choke switch , listen for operation (click)
  • Raise idle speed lever, not too much, be prepared to lower quickly if engine starts to over rev . (remember, this is a 1972, it does not have much for safeties.)
  • lift and HOLD choke switch
  • Turn key to crank
  • release choke when fires
  • if running, you may have to flip choke switch again until it warms up.
  • watch idle speed as 2 cycles can "run away"
  • Hope this helps
  • All of this assumes the motor is in the down position and IN THE WATER or hooked up to a flush device.
  • NEVER start the motor without water going to the gear case(water pump)
Feb 16, 2015 | Boating
How to adj the crab on a poulan chainsaw
if the engine is in good shape..screw in both carb jets adjusting screws till they seat lightly, then back them out 1 1/2 turns, srew in the throttle adj screw a turn and start the motor,,warning if the chain is on make sure the blade isnt likely to touch anything when the engine starts as you will have to have the brake off to get started and adjusted. With the engine running, adjust the throttle srew until it is idling just above shutting off speed, then adjust the "L" low speed jet to get the best idling speed without srewing it in much, reset the throttle srew, then , while trying to accelerate suddenly each time, open the Low jet a little at a time until the machine accelerates smoothly without hesitation. Reset the throttle srew to a position that the chain stops running at idle and check again that the acceleration is without hesitation ( usually with "L" jet about 1/4 turn out more than best idling). The high "H" jet can now be set to give the best power while cutting a block of wood.
Jun 29, 2014 | Poulan Garden
Car starts but won't idle until I accelerate
has base idle speed and kurb idle speed. allows engine to close throttle opening when shutting down to stop pre-ignition or engine running on
Nov 14, 2012 | 1988 Chevrolet Camaro
50cc Scooter won't rev up, Keihin PD18J carb
my 50cc scooter will idle at first and rev very well but wont idle what can this be
Jul 08, 2012 | Motorcycles
We are facing over heating and idling speed is not withstanding machine is getting off when we release the accelerator.
Use compressed air to blow the sawdust and dirt out from the cylinder and head. Clean the screen in the muffler. Make sure that the fuel/oil ratio is correct. Turn both L and H screws in the carburetor CW until lightly seated, then back out 1-1/2 turns CCW each. Start the engine and allow to warm up. Open the throttle and turn the H needle CW until the engine starts to speed up, but is 4-stroking. The correct position is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting is started. Let idle and adjust L CW until the engine runs fairly smoothly, yet allows the engine to 'follow the throttle' as you accelerate it. Set the idle speed screw so that the engine keeps running, but doesn't try to move the chain. Hope this helps!
Feb 22, 2010 | Garden
Boating Logo
486 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
