Question about SuperMicro PDSLE (PDSLEB) Motherboard
Random Shutdown and Beeping
I am having a problem with my motherboard. I have used some memory tests and some other various testing programs. It seems to happen when ever I use a program that uses a lot of ram space. It will shut down and not give me a blue screen of death or an error code but it starts to beep randomly. I then have to turn it off and restart the computer all over again. I have tested teh ram in another computer and it works poperly. This is in my gaming rig so it is kind of a problem to have it fail halfway through a game.
  • Anonymous Mar 23, 2008
    Yea I just tried that and I can't find the options in the Bios. and I don't think has anything thing to do with the graphics card because I am also tryign to install vista on a second partition and everytime it reboots to finish the install it does it. Thank you for the help though
    k I'll try that
    Genius:
  • 1,913 Answers
I think your game's graphic need more shared memory.
go to your biops setup and shared more memory in advancedd option.
then start your sys i think your pro is solved.
Posted on Mar 23, 2008
  • kishor khatri
    kishor khatri Mar 23, 2008
    i think *********** bord get hitting event
    check your heat sink and processor fan.
    check *********** bord not touch thecabinet or grounding.
    first put away your motherbord from cabinet.
    then remove all device and connection except ram, harddisk anddisply option.
    then check your sys isrestart ornot
    check your smps, power cable ,home earthing problem.
6ya staff
SOURCE:
MY COMEPUTER KEEP RESTARTING I WILL LIKE 2 KNOW Y
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory hope this helps
Sep 02, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Random shutdowns
Aug 19, 2011 | Topower PowerBird TOP-1100W 1100-Watt...
After warming motherbord when shut down it restart atumaticaly again
Aug 19, 2011 | Gigabyte GA-G31M-ES2L Motherboard
My board does not turn on and its beeping. Ive counted 7 beeps. i tried replacing the memory with known good ones but still the beeping persist.
MSI states that 7 beeps means "Virtual mode exception error "
Explanation: Virtual mode is one of the different modes that the processor can run in. The system is reporting an error when testing this mode.
Diagnosis: There is a problem related to the processor or motherboard. Note that this doesn't mean that the processor is necessarily dead, since the system won't boot at all with a dead processor.
Not knowing the price of either your processor or the board it is hard to say what to do for the best
Good luck
AMI Beep Code Deep Code Description 1 short DRAMS refresh failure 2 short Parity circuit failure 3 short Base 64k RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed AWARD Beep Code Deep Code Description 1 Long, 2 Short A video error has occurred and the BIOS cannot intialize the video screen to display any additional information
Jun 19, 2010 | MSI K9N6PGM2-V Motherboard
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
Shuts down with long continuous beep or freezes
if you are getting these kind of problems your pc shutdown and after that you hear a long beeping sound, then the problem here is you memory module, remove your memory and have test to other cpu unit if the problems occur there then a new memory replacemnt is necessary
Nov 22, 2009 | Intel Motherboard
Dell vostro 400 2 beeps in bios post test
Hi...
The cause of beeping is the memory problem. maybe the memory stick is not inserted correctly. If your memory stick will not correctly inserted it will damaged the memory slot. Try to use the other slot, if the same thing happen. You memory slot will be damaged you need to bring you motherboard to the computer repair center. Ask first how you will pay, if the labor cost is high. its better to buy a brand new motherboard.
Regards.
ICmanServer
Aug 01, 2009 | Computers & Internet
Programs shut down at random
Have you checked in your case to see if all your fans are working? May be a heat problem in power supply, CPU. Get this software and install to check the actual temps on your motherboard.
This is the free program I use.
http://download.cnet.com/Motherboard-Monitor/3000-2086_4-10518386.html
Here is also a website that talks about overheating problems and solutions
http://hubpages.com/hub/How-to-check-CPU-temperature
Apr 26, 2009 | Gateway GT4022 PC Desktop
ECS PM800 Restarting?
defragging uses a lot of disk drive space and memory. while you encountered a problem during the process of defrag, you may experience some data corruption after the startup, thus, your computer wont boot... only remedy for that now is to do a reformat.
Apr 29, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Open Questions:
See all SuperMicro PDSLE (PDSLEB) Motherboard Questions
Computers & Internet Logo
155 people viewed this question
Top SuperMicro Computers & Internet Experts
Joseph Hoffmann
Greg Ulan
matt
matt
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
