Question about Cycling
How do you install a stage one dynojet kit on a 2003 honda recon? The new jets doesnt fit anywhere and i took out all the stock jets and theres nowhere to put the new oneeessss!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
The dyno jets should look the same as the ones you removed, might have to go back to seller and check kit is the correct one, take your stock jets or take a note of the numbers on them
Posted on Apr 24, 2010
I took off air box added airpods with stock exhaust on a 1981 suzuki gs 650 what size main jets should i replace with
Richard, I would suggest you go with a stage 3 jet kit for improved air flow. Ebay has them for a great deal. I'll post a link. Good luck. ^^
Dynojet Stage 3 Jet Kit For Suzuki GS650 GS 650 1981 1982
Aug 18, 2015 | Suzuki Motorcycles
Runs on half the motor when driving about 10 miles
Honda Shadow carb issue? - YouTube
? 1:09
www.youtube.com/watch?v=8D2fzdIxH5k
May 30, 2013 - Uploaded by Matthew Porter
It's a 2003 Honda Shadow Spirit btw. ... This video How to install a Dynojet Jet Kit in a Honda VT750DC Spirit Shadow is ... Hey, I posted this video right after I had problems back in May of last ...I ended up very carefully (and documenting through taking frequent pictures) stripping down the engine until I ...
Jul 25, 2015 | Honda Motorcycles
1988 Honda CBR 600 F Hurricane assorted carburetor jets
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Carburetors Parts for Honda CBR600F eBay
Dynojet Carburetor Jet Kit Honda 1987 1989 CBR600F 1122 Stage 1 2 eBay
Honda CBR600F4I 2001 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F Owner Manual
Dec 08, 2013 | 1988 Honda CBR 600 F Hurricane
I have 175 and 180 size jets in my carburetor on my 04 Sabre. Are these stock? My Dynojet stage 1 kit has 160, 165, 170, & 175...which are smaller...
It doesnt matter if the jets are stock or not it is a myth that the jets must be bigger when you put a stage one kit in. Remember stock jets are there for EPA standards and what size works to pass is what the manufactor will use. I have many times put smaller jets in a carb even on race bikes to get a better performance. I hope this helps.
Nov 03, 2010 | 2004 Honda VT 1100 C2 Shadow Sabre
What size dynojet main jets are required for honda cbr 600 91-94 in the UK bike fitted with K n N filter and viper end can , and how many turns out on fuel mixture screw. ( lost my instructions) thanks,...
HI A DYNOJET KIT INCLUDES MORE THAN JUST MAIN JETS, AIR CORRECTORS, SLIDE NEEDLES, AND IN SOME CASES NEW SLIDE SPRINGS ARE INCLUDED, SLIDE LIFT HOLES ARE ALSO DRILLED OUT TO GIVE QUICKER THROTTLE RESPONSE, AS DAFT AS IT MAY SEEM YOU NEW MAIN JETS IN MOST CASES WILL BE SMALLER THAN THE ORIGINAL JETS, IF YOU ARE THINKING YOUR BIKE HAS BEEN DYNOJETED BUT ARE NOT SURE CONTACK DYNOJET UK FOR HELP, HOPE THIS IS OF USE FOR YOU,
http://www.dynojet.co.uk/jetkits/index.htm
Oct 27, 2010 | Honda Cb 400 F Motorcycles
Hi,just got a dynojet stage 1/3 kit for my 1980 honda cb650, it's on standard air box, but 4 into 1 exhaust, I take it I should use the stage one kit. Also I have no instructions can you help...
Intended for motorcycles with a stock engine using the stock airbox, air filter and stock pipe. Stage 1 kits are fully adjustable to allow the use of a well designed aftermarket pipes and stock replacement air filters like K&N. Stage 1 kits are designed to improve throttle response and driveability and in most cases power increases of approximately 5% throughout the entire power range can be achieved.
STAGE ONE INSTRUCTIONS
1. Remove the vacuum slide from the carbs. Remove the stock needles & spacers, noting the order of
assembly. Locate the slide lift holes (Fig. A), with the slide drill DD# 14 supplied, enlarge your slide lift
holes. The picture may not show your slide exactly, enlarge your slide lift hole or holes depending on your
model. Do not drill any new lift holes. Do not drill the needle hole.
2. Install Dynojet needles on groove #4, using all stock spacers. Install the Dynojet washers (2 per
needle) above the E-clip.
3. Remove the stock main jets and replace with the Dynojet main jets provided. If you are running with
stock exhaust, use the DJ110 main jets. With an aftermarket header or slip-on with high flowing baffles,
use the DJ116 main jets. Be sure that the jets you are changing are the main jets.
4. Locate the fuel mixture plug (Fig. B), if you see a screw head, proceed to adjusting procedure. With the
DD #5/32 drill bit provided, carefully drill thru the plugs. Note: the mixture screw is directly underneath this
plug, be ready to pull back on the drill the instant you break thru. Use screw provided to secure and
remove the plug. Carefully turn mixture screws clockwise until they seat, turn out 3 turns.
For further info on this, visit: http://www.dynojet.com/jetkits/motorcycle/honda.aspx
You can find the manual for the model you are searching for. Follow the 1st column "CC" to find 650cc models and you can find your specific model after that.
Thanks for asking.
Regards,
Arvind S Iyer
Oct 15, 2010 | Dynojet Cycling
My Sabre has Cobra pipes and a Jet Kit, but I can not get the bike to stop popping when I let off the throttle-Any Help?
its likley to be running a bit to week,, try opening up the fule mix screw just a bit to let in more fule
Apr 03, 2010 | 2001 Honda VT 1100 C2 Shadow Sabre
97 srad no power under 4000 rpm in, in first gear acceleration
If you have installed the Dynojet kit's carburetor needles take them off and use the stock ones.
Dynojet's needles are for track use only and the don't work properly under 4000rpm.
Jun 15, 2009 | 1999 Suzuki GSX-R 600
How many miles to a tank of gas should i get?
this could be a problem. you should be able to get about 100 or 110 miles before switching to the reserve tank, on which you should be able to get 30 or so more miles out of. you may have a dynojet kit installed for your carbs. When the dynojet kit was released for the 1994-2003 magna's, the instructions were written poorly and caused many people problems. one thing to look for if you have the carbs apart are needles that are adjustable. this definately means you have some form of aftermarket kit. (cobra/dynojet/k&n) another downfall to this kit is that they require you to drill each hole larger that are in the 4 vacuum slides which the needles reside in. some kits come with different rate springs and some don't. it is costly to replace the slides and bring it back to stock. (roughly $100/slide x 4, plus the cost of needles and main jets)
first tihings first, replace the spark plugs and go from there. email me if you need a copy of the repair manual in .PDF format. Hope this helps.
chadschloss78@aol.com
Apr 18, 2009 | 1994 Honda VF 750 C Magna
Acceleration problem
If you are not running an open or free flowing exhaust go back to the stock size jets but use the DynoJet parts instead of the stock.
DJ jets tend to run bigger than oem jets
Jan 28, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
Cycling Logo
83 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
