Question about Refrigerators
My mini refridge wont turn on but i plug it in about thirty seconds later it pops and the breaker is really hot.
  • Refrigerators Master
  • 43,501 Answers
I think you may have compressor issues...
As the weather is getting warmer for many people their freezermy mini refridge wont turn on but i plug it in - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
Posted on Apr 23, 2010
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Air lock for my aruba spa hot tub how do i fix it
This sounds like a problem with the circuit board inside the spa control box.Do this:
  • Turn the breaker off
  • Unplug everything that is plugged into the circuit board i.e. the pump, heater coil, air blower, light etc.
  • Turn the breaker back on
If the circuit board stays on then you have to go thru the process of plugging one item at a time turning the breaker on then off to find the part that is bad.
Rod
US Parts Center
888-521-6183
Dec 19, 2012 | Pool & Spa
Breaker popped and wont reset yellow light on arc fault breaker after plugging in small humidifier unplugged but it wont reset
Hi, I don't know if this has been solved or not, but anytime these G.F.I. breakers trip, it is for safety because it is picking up a voltage leak from what ever appliance has been plugged in. If it does not reset, it must be a older breaker and you will need to run down and pick up another one. Home Depot is a good place to get one for around $20. With it tripped, no voltage will be present. Just take a flat blade screw driver to remove the wire from the breaker. Depending on the type/style, most just hook opposite the screw side. Just grasp the breaker where the terminal screw is and give it a pull straight out to you. When you install new one, just hook the right side under the lip, and push left side in place and reconnect hot and neutral coiled wire. You will be set! Always be safe when working around any high voltage source. Please rate me on my help to you. Thank you!
Shastalaker7
Jan 27, 2011 | Siemens Seimens Arc Fault Breaker
After being reset and plugged back into computer to charge, a red light pops on as soon as plugged back into usb port to charge and will not turn on.
Put a pin in the reset button situated in the tripod hole.Do it three times for about thirty seconds each time.Also depress the on off switch for about thirty seconds.Put it in the usb port of your computer to charge.After about thirty minutes or an hour the screen should go white.A battery shows on the screen.Wait till the battery shows all green,then it is fully charged.
Oct 28, 2010 | Pure Digital Flip Mino Digital Camera
IPOD touch got very hot and then turned off and won't turn back on
I tryed those, my ipod will not turn on! This morning it was slow, then froze and turned off and got REALLY hot... I got home (7 hours later) and its cooled down but i cant turn it on? I tryed plugging it in and resetting it, but it wont turn on! it was almost a full battery when it died/turned off..
Nov 06, 2009 | Apple iPod touch
BOTH TOP AND BOTTOM WARM (NOT WORKING)
Check cooling fins under refridge, may need to be vacuumed. Excess dust will cause this to happen, restricts air flow.
Aug 19, 2009 | Amana ARB8057CSL Bottom Freezer...
Inop on ac electric
There should be fuses/breakers in the converter box. It sounds like the DC circuit is ok but the AC portion is still out. Eric
Jun 20, 2009 | Dometic Refrigerators
Refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Apr 03, 2009 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
