Question about Makita Hex Shank 70 Lb. Breaker Hammer Kit - Hm1810x3
Loses power (Maketa Breaker)
Breaker runs for a while then loses power.
    President:
  • 957 Answers
If the air-hammer is working fine at first but then starts to fail as you use it.
I would look at the breaker unit, see if it is covered with frost. These units require a lot of air. A 1inch hose is usually used to connect it to the air supply. If you are not using an oiler, that could be the problem.
Check that the hose is in good shape and is free from damage or kinks.
Check the air gauge and see what the compressor is creating for air.
The compressor should be building and maintaining 125 to 175 psi.
I am guessing that you have this hammer hooked up to some type of worm drive system. Let me know if I can be anymore help.
Posted on Apr 23, 2010
Testimonial: "Thank you very much for the info.Plesae forgive me but I forgot to say my makita breaker is electric. yours very truly bobj3@optonline.net"
  • larry blais
    larry blais Apr 25, 2010
    Oops, no problem, well when you get an air breaker you will know what to look for.
    But I'm sorry but I'm not too familiar with the electric version.
    If you still have the owners manual then take a look, it may need only to be cleaned and oiled. Is it an older unit or newer one? Makita's web site or customer service dept. may be able to help you.
Generator electrical problem
No it sounds like the engine is losing power, as the RPM drops the voltage drops, this increases the current load and that trips the breaker.
Jul 21, 2016 | Electrical Supplies
Still wondering about losing power to all 4 power windows-Help!
What kind of vehicle. Power windows are normally run through a circuit breaker. Is the lockout button on the master switch depressed causing windows not to work?
Apr 08, 2015 | Cars & Trucks
Tripping the breaker
Could be a number of things but I would first suggest that you check the plug (from the TV) for wires touching inside ie: neutral and/or earth touching the phase terminal and/or damaged cable.
Hope this helped
Jan 28, 2014 | LG 42LC2D 42 in. LCD HDTV
Wiring outdoor motion lights (with 14/2) to a nearby outlet (possibly 12/2)that has power. After wiring into outlet and turn on breaker, I lose power, but don't trip the breaker?
First take a cord and hook it to the motion lite and make shure it works .Remember that it only will work at night or dark area and you have to have lights in the fixture to make the contact.and make shure the plug is not on a dimmer or the wires are flipped. WHT. To the common side and black to the darker side and it has to be grounded .exspeacily if it is a led fixture.
Apr 01, 2017 | Cooper Wiring Devices Motion Sensing...
Not getting hot
first make sure theres 240 volts at the dryer plug in ,if not then try resetting your circuit breaker ( or fuses ) if its electrically heated (not by gas) and is plugged into a 240 volt receptacle as even though the breaker may not show its tripped by the little orange window on the breaker it can lose one phase of power ( 120 volts) and still turn but it needs both phases to operate the 240 volt heating element,if you lose one leg of power ( 120 volts ) either the drum will turn or the timer will run (but not both ) because each of these parts only operate on 120 volts or one leg of the 240 volts
Nov 11, 2012 | Kenmore Dryers
DRYER WON'T START
it may be in the start button or it may be a sensor on the door is not working properly. you also may have a breaker issue. on alot of dryers you have a 2 pole breaker and if you lose one side of the power at that breaker it can lose some of its capacity to operate certain functions on your appliance
Feb 17, 2012 | LG DLE5001W Dryer
I picked up a Maketa 12" Planer Model 2012 at a
Got it, go to "makitausa.com" and on the right side top type in your model number in their search box, follow the links to the page where you can download the manual or a parts breakdown. The manual is 20 pages long. Let me know if you need more assistance
Jul 07, 2011 | Makita 2012NB Electric Planers
I have a 5hp 26gal campbells it hums when u turn it on it will either trip the 20 amp breaker or it wil start up most of the time it trips.is it that the breaker is too small or something else.please help.
Could be a couple of things, first, a cord, It might be a 20 amp breaker but if it goes through a cord, it loses amperage and will not start. It needs about 16 amps to start and then about 13 to run. Will it start by being plugged into the wall? Second, let the air out and see if it will go, too much back pressure, not enough power. third, make sure it is warm, We used to heat a bathroom on the job just for the compressors in the winter, of course we all went in there to at break time, only warm spot in the house. And last, If the capacitor is bad, it will lose it's power, but I would check the rest first. Hope this helps.
May 25, 2011 | Air Tools & Compressors
The dryer keep tripping the breaker
It sounds like the current draw is too high This would be due to overload of dryer, motor overheating binding of the drum assy.. First re level the dryer, next disconnect the power and Vacume out the lint inside around moter, try spinning the drum manually to see if it moves freely( some resistance is ok) Another possibility can be lose electrical connections on the breaker or outlet. Disconnect power before testing. Let me know if these tips helped solve issue
May 14, 2009 | Maytag PYE2300AY Electric Dryer
Intermitant dryer heat
i have found that in some model of the kenmore the wire going to the plug on the motor is lose on the conection since the power for the heat runs throw the cintrafugl switch it happens
Mar 18, 2008 | Dryers
Makita Hex Shank 70 Lb. Breaker Hammer Kit - Hm1810x3 Logo
130 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
