I purchased CD Micro Component System (Silva Schneider NE-1300) in 2003 in Korea. When I left Korea in 2004 the packers did not pack my connecting control cable to my system. I need the connecting AC Power Cord in order to use the system... Is there any way I can purchase a new AC connecting power cord.
s4u311
  • 813 Answers
SOURCE: lost power cord for boombox
hi friend
take your boombox nearset electonics & electical store he wil give u a maching code
thnx using fixya
Posted on Apr 08, 2008
SOURCE: power cord Cd player mod. #CD-1095
Answer below from:
http://wiki.answers.com/Q/How_do_you_get_a_cord_for_a_Durabrand_CD_player_model_cd_1095
You can purchase a generic power cord at Radio Shack. I had the same exact model and found that their catalog number 61-2875 was a perfect fit. It lists for $7.99. To be sure, take your radio in for an exact match. Good luck! :o)
Posted on Oct 25, 2008
cnavarro
  • 2460 Answers
SOURCE: I have a 3 pack
Start by putting in the very same part number you put in here.
It will lead you to the base without power supply, and a reference to a KX-TC1 power supply. How about this one?http://www.google.com/search?q=kx-tca1&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
Carl
Posted on Dec 26, 2008
SOURCE: Need new LG AC Power Supply Model H-P 220
I had a similr problem It turned out that the power supply cord was not the problem, it was the main battery. Luckily, in 2000, I bought 2 extra main batteries. I took out the old battery and put in one the 2 new unused ones and my machine is working and charging perfectly now.
Posted on Feb 16, 2009
  • 10865 Answers
SOURCE: Need Philips AC Adapter (AY4109/17) for Philips Go Gear SA9200
take your player to radio shack. they will have what u need.
please mark this answer as a fixya! thanks
Posted on Mar 08, 2009
Silva schneider ldt-42-150dvb
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 10, 2014 | Televison & Video
Connexion problems
Silva has shut down the Silva Connect web site. They had a replacement package available up until February 1, 2013. Unfortunately, if you only recently got the EX3, you need to return the pedometer to the place of purchase and get a different brand's pedometer. Otherwise, copy the data manually into your own spreadsheet by viewing the seven day record using the memory. Press and hold Mode for two seconds to access the memory. Then use Set to select a particular day. (You won't be able to get the 30 day history.)
I wish that I had better news for you. The announcement of the closure of silvaconnect.com was posted in August 2012; it's available here: http://silva.se/silva-connect-closedown .
Feb 13, 2014 | Silva Exercise & Fitness
Silva-Schneider LTD82-100HD
Although my remarks are not a direct answer to the question you asked- and until someone else on this forum has a definitive answer to your question, may I suggest you call or visit an electronics or tv repair center? Perhaps they can assist you!? I wish you well and success on you do-it-yourself project.
Dec 01, 2013 | Televison & Video
Betrifft: Silva-Schneider SAT COMBI RECEIVER Modell Gran Prix STR 755HDD # 070907424 made in Germany Das Gerät folgt seit kurzem der Fernbedienung nur in sehr eingeschränktem Maß; es...
Dear Sir,
I think I have the same problem.
Can you share with me, what was the solution, if there was anything.
Thank you
Zsolt Bozsik
bozsikzs@gmail.com
Feb 19, 2010 | Televison & Video
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Wharpdale NE-3272 CD/DAB Micro System - This is brand new and switches its self off. Hiw can I get it to continue to play all day?
Need to clean and resoldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click to rate.It is the only way i get paid for my work...
hope this may help;
Regards,
VOTIT
Jul 27, 2008 | Audio Players & Recorders
Micro solutions Back Pack
It's a standard DB25 pin cable. Male on one end female on the other.
What's the voltage of the power supply for your unit? Mine is missing the power supply. (kids)
May 17, 2008 | Micro Solutions (212010-USA-INT)...
No sound while playing dvd/cd
sound muting circuitery prblem or sound swiching section problem can occure this type fault.sometimes it can be cd /dvd printed board problem.give it to qulifid technician .
nuwan.
Dec 12, 2007 | JVC FS-S77S DVD Micro Component Stereo...
158 people viewed this question
 Grubhead
Grubhead
