Question about HP Pavilion DV6700T Notebook PC
I broke the screen on my lap top and not sure what the resulotion is i have a hp pavilion dv6700
    Scholar:
  • 48 Answers
The DV6700 model carries the 15.4 WXGA High-Definition inch display, which outputs a maximum resolution of 1280 x 800.
Posted on Apr 23, 2010
Hp pavilion dv6700 has blank display
If you have access to a monitor plug that into the laptop and see if you have a picture if you have it probably the invertor that lights the backlight its behind the screen at the bottom
cheers
Sky
Jun 08, 2014 | HP Pavilion DV6700Z Notebook
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
Jan 14, 2012 | HP Pavilion dv6915nr Notebook
I have installed the WRT120N wireless router at home. My PS3 detects it, my lap top also connects but my wifes lap top does not. The HP Pavilion DV6700 notebook PC does connect but the internet does not...
first check your wireless setting then connect with wireless router
this problem is from your laptop you have to enable the wireless acces then you will be work properly.
May 07, 2011 | Linksys WRT120N Router
The laptop is a dv6700 HP Pavillion. What steps should I take to solve this issue.
About it being an HP Pavilion dv6700 laptop?
Ehhh, giveittome. I will use it.
Looks like I'm going to have to guess since the 'Issue' wasn't stated.
The main problem with the Pavilion dv6700, which is part of the Pavilion dv6000 series of Notebook PC's, is that all the indicator lights come up, but there are no graphics being shown on the LCD screen.
The screen is black.
This is due to a graphics chipset problem, caused by a poor cooling design of HP designers.
The graphics chipset (GPU. Graphics Processing Unit), is mounted to the motherboard in a BGA surface mount.
Instead of pins coming off of the bottom of the chipset, as on the older Processors, there are Solder Balls.
The motherboard has tiny copper pads that line up to the solder balls.
The graphics chipset is set into place, then heat is used to melt the solder balls, and attach the graphics chipset to the motherboard.
Due to the poor cooling design, the graphics chipset overheats, and the solder connections are partially melted.
The graphics chip now has a poor contact to the motherboard.
This video shows you what's going on, and how to solve the problem,
http://www.youtube.com/watch?v=bnkQNmKauEc
This is the download page from HP Support, for the Service Manual (free) for the HP Pavilion dv6700 model series of Notebook PC's,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3650965&
On this page click on the file name in blue>
HP Pavilion dv6500, dv6600, and dv6700 Entertainment PCs - Maintenance and Service Guide
This is a PDF file. Allow up to 30 seconds to see the first page, and additional time may be needed to full download.
Regards,
joecoolvette
Dec 08, 2010 | HP Computers & Internet
Hi I have a hp pavilion dv6700, when I press the
Go to this link: www.hp.com
  1. click on support & drivers
  2. enter a product name/number which is: Hp Pavilion dv6700, then click go
  3. click on HP Pavilion dv6700 CTO Notebook PC
  4. select your operating system, and click next
  5. click on the + sign by keyboard, mouse and device input then click on HP Quick Launch Buttons and download it
  6. after it downloads open it up and follow directions to finish install
Nov 16, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
I have virtical lines on lap top
Once you start to get vertical lines on your LCD screen, it's usually time for a new screen. I would check first by running an external monitor just to be sure it's not the video card.
May 19, 2010 | HP Pavilion zd8000 Notebook
HP Pavilion dv6700. no screen.
Please run system restore to an earlier date.
Start system holding down f11 key till you hear a beep then follow the screen instructions.
Good luck.
Mar 21, 2010 | HP Pavilion DV6700T Notebook
I HAVE A HP DV6700 LAP TOP HOW DO YOU CHANGE THE HARD DRIVE
The official service guide:
http://h10032.www1.hp.com/ctg/Manual/c01295877.pdf
Nov 13, 2009 | Computers & Internet
Drivers
What drivers do you need? If all drivers, try this link to download a software to do this for you:
http://www.laptops-drivers.com/hp-laptop/pavilion-dv6700-xp-hp-software-update.html
Mar 24, 2009 | HP Pavilion DV6700T Notebook
HP Pavilion DV6700T Notebook PC Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
