Question about Lexmark X2500 All-In-One Printer
I was forced to change the ink in my lexmark x2500 now it says i need to align the cartridges by printing the sheet and scanning it... i could do all that if my scanner wasnt broken. Is there any way to bipass this?
  • 3,153 Answers
I am unsure of the EXACT steps but yes you cab BYPASS the alignment process.
If you print photographs however the MINOR misalignment may be an issue as mentioned previously by Rulds.
For most general purposes it should however not be an issue.
Posted on Apr 23, 2010
My Lexmark X2500 All In One printer will not come on at all. The contacts where the power cord is inserted were bent pushed back and were not making contact but I put them back in place and it still will not power up. Does anyone know what the problem may be and how to fix it?
Posted on Jun 16, 2010
  • 3,866 Answers
Say you did get around to bypassing this step. Your printer will be so horribly mis alligned. So your answer is no. I would not instruct someone to bypass instructions that is given by a printer. if the scanner is dead then repair needs to be done before you have more issues with the print heads. I mean face it if there was a way to bypass you would have the answer. But to be truethfull here I would say no and leave it at that and hope for your ratings to be forthcomming.
Thanks
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2010
    I have a lexmark and have worked on them in the past,present and future. There will be a noticeable change if you bypass a allignment and see speaking of this no expert knows how to bypass it on here. If there was such a bypass we would see that bob came up with this solution. But since I wear the lexmark bange I will hope you trust your gut feelings on here.
    Thanks
I recently replaced my ink cartridges for my Lexmark X2500 with brand new ones, Lexmark brand, I inserted them and followed instructions and now it still tells me that it can not print that I need new...
  • Open up the "Printer Solution Center." If there is no icon on your desktop for your Lexmark printer, click on the "Start" menu button, which is located at the bottom left-hand corner of the screen. Click on "All Programs," and then look for "Lexmark." Select the "Printer Solution Center.
    Choose "Install a new printer cartridge" under the "Maintenance" tab.
  • Click on "Next" until you see the "Print the Alignment page" option, then choose "Print."
  • Repeat steps 1,2 and 3 if the ink level gauge still isn't showing sufficient ink.
  • Apr 13, 2011 | Lexmark X2500 All-In-One Printer
    I replaced both cartridges in my x2500 with new cartridges but the printer still says I need to replace them. What to do?
    Your cartridge nozzles may need to be cleaned. Open the Lexmark Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
    Apr 11, 2011 | Lexmark X2500 All-In-One Printer
    Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
    Did you try to align the unit manually or with the computer?
    Alignment page does not print
    1 Make sure you remove the sticker and transparent tape from both print
    cartridges.
    2 Make sure the color print cartridge is secure in the left carrier and the black
    print cartridge is secure in the right carrier.
    3 Make sure you loaded the paper correctly and did not force the paper into
    the printer.
    Aligning your print cartridges without a computer
    Make sure you follow the steps on the Setup sheet to complete hardware
    installation. Continue with the following steps to optimize print quality.
    1 Make sure you have loaded paper into the paper support, and then press
    and hold Scan for three seconds. For help, see "Using the control panel"
    on page 4.
    An alignment page prints.
    2 Place the printed alignment page onto the scanner glass.
    3 Press Scan. For help, see "Using the control panel" on page 4.
    Once scanning is complete, your print cartridges are aligned for optimal
    print quality.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    Nov 15, 2010 | Lexmark X2550 All-In-One Printer
    Do I NEED 2 ink cartridges on the Lexmark 2500. Never use the color ink. Installed new black cartridge, did the alignment and now printer won't let me print. Help
    Yes you do need 2.
    All ink cartridge bays has to be filled with a working cartridge, for the print driver to allow you to print. That is why I prefer single ink type printers, so it is not so expensive to maintain the inks you don't use.
    Mar 10, 2010 | Lexmark X2500 All-In-One Printer
    I replaced the ink cartridge and the alignment screen did not come up, and a result I can't print now. It always came up before. It was printing before I changed the cartridge. How do I solve the problem
    Remove the ink and check to make sure that you removed the sticky tape tab from the bottom of each cartridge. If you have then check the carriage where the ink sits for any dry or caked on ink. You can wash this away with alcohol and a cotton swab. Finally check the number on the old ink and make sure that it matches the number on the new ink. Just because the ink fits in the printer does not mean it will work. If everything is good, force the alignment through the printer properties in Windows.
    Dec 11, 2009 | Lexmark X2500 All-In-One Printer
    Changed ink cartridges cannot print alignment page, out of ink
    You need to reset the ink level before the printer can print further, to do these please follow the following step:
    1) Goto the Lexmark Solution Center application.
    2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
    Then try again with printing alignment task.
    Hope this help.
    YBC (/\)
    Feb 26, 2009 | Lexmark X2500 All-In-One Printer
    ONLY WANTS TO SCAN
    Once the alignment page is print you need page the page in the scanner bed and hit the scan button on the printer once it done you be able to print again this process is know as scan back alignment ..
    Good luck.....
    Oct 25, 2008 | Lexmark X2500 All-In-One Printer
    Won't print anything. always wanting to print a test page
    hi this is a ink catridge align ment problem. u do one thing. go to printer properties and printer priference and go to service tab than u check ink catridge align ment.. than ur printer working fine...
    Aug 18, 2008 | Lexmark X2500 All-In-One Printer
    Ink Cartridge Alignment
    On alignment sheet, do you see a line of yellow blocks?
    And on next line do you see alternate block and yellow blocks?
    (Without these, alignment fails)
    If not, change the colour cartridge, re-print the page and repeat alignment.
    Good luck...
    May 26, 2008 | HP PSC 2110 All-In-One InkJet Printer
    Lexmark X2500 All-In-One Printer Logo
    341 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
