Is my 2nd question ready to be tackled yet? Do you still have it, or do I need to type it again?
  • 781 Answers
What's your question?
Posted on Apr 23, 2010
1994 Buick Regal 3.8L v6 auto, I down shifted to low 2nd from drive, and I heard a hard thunk. Now when in drive my car is stuck in first gear and wont shift up into 2nd, and it doesnt reverse. Help?
YOU NEED TO SEE A TRANSMISSION MAN, THIS DOES NOT SEEM TO BE A JOB AN END USER CAN TACKLE. aLMOST CERTAINLY GEARBOX TROUBLE I am afraid
Good Luck with it
May 30, 2015 | Buick Regal Cars & Trucks
Why am I finding thick green grease/oil coming out of the casing on the bottom of my 2000 Evinrude F 115 hp boat motor after and while running?
it needs to be seen by a mechanic, symptoms are not good. Not something to tackle without experience, with all due respect to yourself.
May 28, 2015 | Cars & Trucks
How to interpolate
In Stat mode (press MODE 1) choose the type of data you are working with, e.g linear or quadratic data.
Type in your data points by typing in the x-value pressing (x,y) button, the y-value and CHANGE.
Once you have entered all your data press the ON button.
If you want to predict or interpolate the x value given the y value, you need to type in the y-value and press 2nd F and the ( button. Do you see above ( there is an orange x'?
To predict the y-value, type in the given x-value and then press 2nd F and ) button. Again above this button in orange you will see y'.
If you would like the equation of the line you will see a blue a, b and c above the ( button, ) button and x button. Use the ALPHA to access these functions.
Apr 12, 2014 | Sharp EL-506 Calculator
How to calculate 1.025^4
How to Use a TI-30XA
The TI-30XA is a scientific calculator with many functions. You can calculate problems with fractions and decimals, as well as solve problems of probability and functions. A scientific calculator computes the number sentence you type in using the order of operations: parentheses first, then roots and exponents, then division and multiplication and, finally, addition and subtraction.
Instructions
  1. How to Use a TI-30XA
    • 1
      Press the [ON/C] key to turn on the calculator. Press the [OFF] key to turn it off. To use the calculator in solar mode, put the solar panel in the light and then press the [ON/C] key. To turn it off when in solar mode, slide the calculator cover back on and it will automatically shut off.
    • 2
      Replace the batteries by first removing the cover and placing it face down. Use a Phillips-head screwdriver to unscrew the back panel. Remove the back panel and change the batteries. Screw the back panel back on. Press [OFF] [ON/C] and [ON/C].
  • Use the basic operation keys for addition [+], subtraction [-], multiplication [x] and division [/]. To change the signs of your values from positive to negative or vice versa, press the [+ -] key before the numbers you enter. Use the parentheses, [(] and [)], to command the calculator to solve what is inside the parentheses first. Press the [=] to solve the number sentence you entered into the calculator.
  • 4
    Find percents of a number by first typing in the number, then [x], then the percent number, [2nd], [%] and, finally, [=]. The [2nd] key allows you to use the commands that are written above each key. For example, to find 20% of 100, type in 100 [x] 20 [2nd] [%] [=] and the display will show the answer, 20.
  • 5
    Turn decimals into fractions by entering the decimal value, then pressing the [2nd] and [F D] keys, then [=]. Turn the fraction back into a decimal by pressing [2nd] and [F D] again. For example, to turn 0.5 into a fraction, type in 0.5 [2nd] [F D] [=].
  • 6
    Turn mixed numbers into improper fractions by entering the mixed number first. Type in the whole number, then the [a b/c] key, then the numerator, the [a b/c] key again and the denominator. Next, press [2nd] [d/c] [=], and the calculator will convert your mixed number into an improper fraction. Press [2nd] [d/c] again to turn it back into a mixed number. For example, to turn 1 1/2 into an improper fraction type in 1 [a b/c] 1 [a b/c] 2 [2nd] [d/c] [=], and the display will show the answer 3/2.
  • 7
    Switch the notation setting of the calculator between engineering, scientific and floating. To select scientific notation, press the [2nd] and [SCI] keys; this will display your answers in scientific notation as a number between 1 and 10 to a power of 10. Press [2nd] [ENG] to switch to the engineering setting; this setting displays values as a number with an exponent that is a multiple of 3. Press [2nd] [FLO] to switch to the floating setting. This is considered standard notation and will display the answer as a standard number.
  • 8
    Use the left arrow key to go back and delete numbers to the right of the cursor that you typed into the display. This must be done before you press [=]. To clear the screen, values and operations, press [ON/C] and [ON/C] again in battery mode, or [CE/C] and [CE/C] again in solar mode.
  • Hope it helps your problem. Thanks!
    Jan 03, 2013 | Texas Instruments TI-30XA Calculator
    I need to fix hubbs and berrings on 2001 ford focus
    you'll need air tools, a 5000 ton press, and an alignment,,, you ready to tackle this job ? lol
    Oct 20, 2010 | 2001 Ford Focus
    CLC 5100 error code: E194-0101
    Go to Service mode (Function _ Install _ 2nd Screen i.e. 2/4 make img reg 0 Restart machine Again Go to intall press init c aftrer complition press sinitc aftre getting it ready again make img reg to "1"
    Jul 19, 2010 | Canon CLC 5100 Copier
    I need to enter a 3 x 3 matrix. It is 4 columns and 3 rows. How do I enter it in the TI-83 +?
    1. Press [2nd] [X to -1] under [MATH[ to access the (Matrix) menus.
    2. Use right arrow to highlight [EDIT]
    3. Press [1:A] to edit (create from scratch) the A matrix.
    4. On the line MATRIX[A] line cursor blinks on 1
    5. Enter m dimension (3) and press [ENTER].
    6. Cursor moves to the second dimension (n). type 3.
    7. Press [ENTER].
    8. A 3x3 matrix template is displayed with A_11 element highlighted.
    9. Replace the value 0 with your value for A_11.
    10. Press [ENTER].
    11. Type a value and press [ENTER].
    12. When finished, press [2nd][QUIT] to exit the matrix editor.
    Your matrix is ready to be operated on (squaring, multiplication by a scalar, inverse if matrix is non-singular, determinant.) All operations are available under [2nd][X^-1](Matrix) [=>][MATH].
    Feb 03, 2010 | Texas Instruments TI-83 Plus Calculator
    My 2002 tdi golf's MIL light came on
    You will need to have the OBD codes read to establish the exact cause of this problem. Its the only way to be certain.
    John
    Sep 14, 2009 | 2002 Volkswagen Golf
    Computers & Internet Logo
    13 people viewed this question
    David Payne
    David Payne
