Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
Can't find my disc for reinstalling the Linksys Wireless-G PCI
The adaptor is in but the computer will not read it.
  • 39 Answers
Lost contact try to changes the adaptor ,.
Posted on Apr 23, 2010
My cisco linksys ae1000 adapter does not have internet connection
If haven't yet check Device Manager, go to Network Adapters and look for Linksys Wireless Adapter. Check the status of the adapt
Also look for errors codes on anything. Make sure all is enabled or need to install drivers.
If all fails remove adaptor and all drivers for it, restart computer and reinstall adaptor.
Aug 04, 2014 | Cisco Linksys AE1000 Wireless-N USB...
Says my linksy adaptor is inactive. would not go to setup wizard after files downloaded from startup disc.
You can try first removing all the Linksys software from the computer and then after that unplug the LInksys adapter from the computer and restart the computer.when the computer is already up you run again the setup CD and follow the steps again and you can already connect the Linksys adapter before running the setup so the computer will detect it already...
Aug 15, 2009 | Linksys Wireless-G WPC54GX (DHWPC54GX)...
Computer does not see PCI card
Run a viral check on the card, as the fact that the malfunction occurred while on a public hotel's wifi,
leads me to the belief that you have been hacked with a keylogger.
Just to make sure, you might want to obtain another PCI card as a check, since you have already done everything I would have suggested, including reinstallation, and thereby have eliminated all but
the internal functioning of the card as suspect.
Apr 13, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Computer crashed, reset to factory, lost info for linksys adaptor
If you download them to the desktop of the laptop and burn to cd or copy to flash then you may have something going. See if they will d/l to desktop from linksys site.
Mar 15, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Cannot setup WPA2 on WUSB54G & WPC11 adaptors
This is because those wireless adapters that you mentioned do not support for WPA2. Linksys will not release drivers for those adapters that will make it work with WPA2 because they are already discontinued. So the only other option is to stick with WPA or WEP
Jan 19, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Dec 16, 2008 | Computers & Internet
Server not found No internet connection
Does the access point you are trying to connect to have encryption enabled?
Aug 28, 2008 | Linksys Wireless-G Broadband Router
After installing cd and following directions to install my Linksys wpm300n wireless-n pci adaptor the directions say to power down pc,installcard hookup antenna and re power up pc.but i get no futher set...
Click on Start - right-click on my computer - click on properties - click on hardware - click Device Manager
Look for your wireless adaptor in the list. Probably under Network adaptors. If it is on the list and there are no yellow question marks or Exclamation points next to it then you have successfully installed the device.
If there is an item that says unknown communication device with a yellow question mark next to it (?), put the set up disk back in and reinstall.
Most of the time when you install a new device in a pci slot, you must install the device physically in the computer first before running setup.
May 03, 2008 | Computers & Internet
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
98 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
