Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Resetting lamp life after changing lamp
How do I reset so I don't get the message everytime I turn on the tv
    Guru:
  • 416 Answers
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps, best wishes.
Posted on Apr 23, 2010
Testimonial: "thanks that did the trick"
  • Adam Halfhill
    Adam Halfhill Apr 27, 2010
    This didn't reset the lamp timer? Let me know... 2 thumbs... not good.
Recently changed the oil for my 04 silverado, but the change engine oil warning will not go off, how do i correct this
After changing the oil and filter, reset the monitor by proceeding as follows:
Turn ignition On, but do not start engine.
Fully depress and release accelerator pedal three times within five seconds.
If CHANGE ENGINE OIL lamp flashes for five seconds, this indicates system has reset.
Start engine. OIL LIFE should change to 100%.
If CHANGE OIL SOON lamp lights again, repeat reset procedure.
2001-08 Silverado, w/Driver Information Center
Press MODE button until DIC (Driver Information Center) reads OIL LIFE LEFT/HOLD SET TO RESET.
Press and hold SET button until 100 percent is displayed. You will hear 3 chimes and CHANGE ENGINE OIL SOON message will go off.
Turn ignition Of
how to reset oil life on 2004 chevy silverado
Nov 10, 2016 | Cars & Trucks
Reset lamp message
What make and model of TV ?????
May 08, 2014 | Televison & Video
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
Tv wont stay on . i changed the color wheel and bulb and now it turns on then shuts it self off right away and the lamp light is flashing still
When you changed the lamp did you clean the "lamp temp sensor"? When you removed the lamp housing from its cradle, you can access it from where lamp goes. It can be cleaned with a Q-tip.
Also, there is a little blue safety switch that is located on bottom right of the light engine tray. It MUST be in the DOWN position when the TV back is reattached to TV. You can use tape to hold it in the DOWN position while attaching the back of set.
Also after replacing your lamp did you reset the lamp life?, You can do this by:
1-TV off
2-press mute+1+8+2+Power. This will access factory settings.
3-scroll to "Options". Press right arrow to next menu. scroll to "lamp life" hit right arrow and click reset.
4-power off.
That resets the lamp life hour meter.
Apr 09, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Need to reset the lamp timer
1 turn tv on
2 press vol- on tv and pip on remote at the same time for more than 5 sec a message will appear
May 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
My sony KDF-50E2000 TV has screen message coming up that says projection lamp life is expiring, is the XL2400 the proper replacement and will that correct the problem
Yes XL2400 is correct number. Replace Lamp message is a timed message that will reset and turn off if you unplug TV when lamp is removed and replaced.
Mar 02, 2010 | Sony KDF-50E2000 50" HDTV
How do I reset Lamp in PT40LC12 with out a remote
After turning on the TV and viewing the message to "reset the lamp" I became frustrated and attempted to shut the TV off by pushing the power button. A message popped up saying "Do you want turn the TV off Yes / no.
I toggled down using the volume/Channel button on the tv to say no. The next thing i know...The TV picture came on and the la,p was reset!!! I really don not know how this happened! but it worked! Thanks for your assistance. Now, i can program a remote!
Oct 23, 2009 | Panasonic PT-40LC12 40" Rear Projection...
How do I reset Oil Life warning Message
Turn ignition on,need not running.Hold the reset button in until oil life xxx% blinking ,let go the button.Then hold it in again until it shows oil life 100%.Done
Apr 27, 2009 | Honda Accord Cars & Trucks
Reset lamp life counter pt-50dl54j
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Feb 19, 2009 | Panasonic Televison & Video
After lamp replacement
Sounds like the plug is not making a good connection needs to be seated better.
Dec 10, 2007 | Optoma RD65 65" Rear Projection HDTV
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
185 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
