Verticle lines on computer monitor & lock up computer
While working on my computer, verticle blue lines appear and lock my computer. The lines are of various shades and i need to reboot my system.
  • Anonymous Mar 24, 2009
    as above
    system.
  • 3 Answers
Mine turned out to be a stuffed motherboard needed to be replaced
Posted on Jun 29, 2009
    Scholar:
  • 67 Answers
I'm just guessing but it sounds more like the video card than the monitor, as your computer freezes. I would try another monitor, if available, to see if it still happens. I would also open the computer and pull the video card and reseat it. If it's an "onboard" video, I'd suggest putting another video card in an empty slot to see if the problem goes away.
Otherwise, I'd suspect memory, or the motherboard itself. Have you had any lightning or major power outages lately? A surge suppressor is not necessarily proof against such things, as many believe.
Posted on Mar 24, 2008
SOURCE:
Verticle lines/streaks down screen
The Display panel could be bad/damaged or the main board that controls every thing could be bad---parts for Dell equipment are known to be hard and sometimes impossible to find.
Dec 07, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Verticle thin blue line on my IBM ThinkVision Monitor?
it may be a permanent damage on your monitor. i think it is unrecoverable.
Jul 16, 2017 | IBM ThinkVision L200p 20.1" LCD Monitor
Hello sir my samsung lcd monitor model no 740N . in dis monitor right side display two verticle lines green n light pink but hoe to i resolved dis problem please give me suggestion
You cant resolve it tiny resistors in the screen have failed and that is why the lines have appeared, it is a case of live with it or buy a new monitor
Feb 24, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
My screen has verticle lines and the colors are incorrect
Try your monitor on another computer (laptop or desktop), to see if the problem "follows' the monitor.
Try another monitor on your computer, to see if your computer's video-card is creating the problem.
Try a different "data" cable between your computer and your monitor, to ensure that all 3 "primary" colours are being transmitted.
Jul 21, 2010 | Dell Y4694 Dell MOTHERBOARD INSPIRON 9300
One verticle line is appearing
>enter your bios and check if the lines appear, if it is then that line are dead pixels of your monitor and that could not be fixed anymore
>if the line does not appear on bios then it is possible that your video card or cable must be the problem
Jun 05, 2010 | LG Computers & Internet
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
May 05, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
Do these work as tv monitors as well?
jon_bailey, Some monitors do, and some monitors don't have that capability. If your unit has other types of baseband audio/video inputs and supports the old 525 line video signal it might work. Do you see any RCA type jacks on rear of monitor? RED, GREEN, BLUE for input of video with sync on blue? do you also see some inputs called H and V for the horizontal and verticle sync signals. You will need to contact ADVUEU TECH and try to download a .pdf file of the owners manual to find out all of the units capabilities. Bye for now. 12fixlouie
Dec 01, 2009 | Advueu Technology ADV178 17" Flat Panel...
What can cause a single red line to appear on my laptop LCD screen? It's a small/fine red line appear horizontally (left to right) It's NOT radio interference,back light,broken ribbon cable,or connector...
Thats a generic problem with LCD screens. Its more common in Mobile screens. Sorry, no there is no fix to it other than replacing the LCD itself. Just pray that it shall not grow because as and when the compressed gas from within the LCD will leak the line will be becoming broader and broader. It is caused by damage to the LCD corner Just a hit on side of LCD and a hairline crack for giving way to the encapsulated gas.
Jul 28, 2009 | Computers & Internet
Verticle lines on monitor
Hi...there,
Well... I hate to say, but you got a damaged panel. Thinking of replaced the panel... you can forget it.
Get a new one...it's will saved you the headached and $$$... Have a nice day!
Oct 02, 2008 | IBM ThinkVision L170 17" LCD Monitor
Computers & Internet Logo
725 people viewed this question
Ekse
Alun Cox
