Question about Orion1934 19" TV
Need codes for rca converter box
With rca converter box remote tv will not work power or volume need codes
4 Suggested Answers
SOURCE: orion tv need codes for remote control.
I need help with remote control rca r5464 for orion tv
Posted on Dec 21, 2008
gopakumarg43
  • 75178 Answers
SOURCE: i need a 3 digit code for RCA converter box for a
Hello
You haven't given a clear problem post ebefore me. You have only give the model number and brand name of your TV only. Not give the model number of your RCA converter box. Yet i posts a solution to your problem, assuming that your RCA Converter box model number is " DTA 800B1 " The three digit setup codes for Orion TV with this RCA converter box are: 029, 189, 200
ok
gopakumarg43
Posted on Oct 07, 2011
gopakumarg43
  • 75178 Answers
SOURCE: i need code for a orion tv to work on RCA universial remote
Try these codes:
035/ 121/ 135
0121 0135 0035
Posted on Mar 29, 2012
I need the code for rca digital conv.box
Which code? For the Universal Remote? If so, it has a scanning function on it.
Dec 18, 2011 | RCA Analog (RCA) to Digital (VGA)...
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Jul 31, 2010 | RCA Televison & Video
NEED CODES FOR RCA CONVERTER BOX TO PROGRAM TV TO REMOTE
Good day,
I might be missing something here, but if YourTV has the basic controls on the TV itself, such as on/off volume, and channel select, then just turn on tv, and set it to channel 3.
Use your converter box remote to scan for channels, and other options it has as needed.
Jan 23, 2010 | Televison & Video
I lost my remote for my rca converter box this remote works with my tv but wont on the converter box. Is there a code i need to make it work? or do i need another remote?
I can help you reprogram your RCA RCR311B for all your converter box.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
Dec 30, 2009 | RCA RCR311B Remote Control
Hi, I need the codes for my RCA Digital Converter to control TV
I located the list of TV Codes and was able to program my TV with my RCA Universal Remote. Thank you for your concern.
Dec 14, 2009 | RCA ATSC21 DTV Receiver
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Converter box remote will not program
i have a admiral tv and i'm wanting to program my remote that goes to my converder box to the tv is there anyway i can do that?
Dec 27, 2008 | Insignia IS 20" TV040919 TV
New Rca DTV converter / panasonic tv trying to get remote to work
You must set the code to conect your tv to your remote. The instructions are in your manual with a list of codes.
Nov 25, 2008 | Televison & Video
Remote code for TruTech dw19tt
TruTech is made by Daewoo. I entered Daewoo codes from my digital converter box list. The sixth code I tried made it work (140 for an RCA converter box). Now the Converter box remote will control volume and power on my Trutech DW19. Regards, tmjl.....
Jun 09, 2008 | Televison & Video
Orion1934 19" TV Logo
243 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
