Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Kenmore 27-stitch machine jamming badly in bobbin
We have two Kenmore 16782 machines and both are jamming badly in the bobbin casing. I have changed bobbins, needles, re-threaded, vaccuumed and cleaned many times but the problem continues. Help!
    Scholar:
  • 48 Answers
Sounds like a timing issue. Did you attempt to force fabric through too quickly? Sometimes this can alter the bobbin's tension, and alter the timing of the machine as a whole as well. Not a cheap fix, sadly(Local to me, for example, this will cost about 70 bucks to have fixed. Do NOT try to do this yourself, leave it to the professionals, there are more moving parts in a sewing machine than in a space shuttle.)
Posted on Apr 23, 2010
Help trouble-shoot jammed machine
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
Upper thread gets jammed in bobbin area
Dec 12, 2012 | Brother Sewing Machines
Kenmore sewing machine jams and breaks the needle
always make sure the needle is inserted correctly and all the way
up into the needle holder
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin case is inserted correctly in to the machine
if it's a front or side loading bobbin case
make sure the top thread has not come off the top thread take up
lever
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 01, 2012 | Kenmore Sewing Machines
Brother 700e
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
Cannot get bobbin thread to come up
have you tried changing the needle?
have you tried turning the bobbin the opposite way?
May 22, 2012 | Brother CS6000i Computerized Sewing...
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
The bobbin case sounds loose and the thread jams with the fabric and everything gets stuck.
That use to concern me too! I thought it signalled a problem, but my bobbin case has always been loose and that was not what was causing my thread and fabric jam. Usually what causes the jam is an incorrectly wound bobbin, wrong needle or old needle, old thread, or a slightly warped bobbin that is hard to see/detect. Change everything out--needle, thread, bobbin...this usually does the trick!
Mar 24, 2010 | Husqvarna Rose
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
281 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
