Question about Fisher and Paykel GWL11 Top Load Washer
Model gwl11 load keeps losing its balance and
Model gwl11 load keeps losing its balance and shutting itself of. How can I check to see if the springs that hold the tub center are still connected?
  • Fisher and P... Master
  • 713 Answers
Undo 2 screws at front of machine under lid. they will have plastic covers over them. lift the hob gently and u will see 4 suspension rods holding the tank. before u do this try this. wind the 2 back feet down and the 2 front feet up about 1 inch . this will make the bowl lean towards the front of the machine away from the out of balance lever, which is at the back right. try this see how u go. please reply 4 more help
Posted on Apr 24, 2010
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
Looking for that spring ( it broke) that holds the tub in the middle because it was overloaded. aThe tub is now very tilted
Hi mate - check this request for assistance.
By brianw307 on Jun 18, 2011
F&P OUT OF BALANCE PROBLEM
Jun 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing Machine shuts off by itself during cycle
Not sure what you are saying.. if washer is off balance, it will shut off, check legs are secure to floor and unit is leveled. If washer lid isnt sealed or lid switch is bad it can shut off at spin or start cycle. Depends on unit model. The smell can be a burning belt from a heavy wet comforter or you have mildew from water not properly drained from unit.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL10U2 tends to get out of balance no matter how big or small the load is.
i would have a look inside of it as there are some springs that hold the drum in the right place if one of the springs has broken or fell of this is the reson its jumping round the room on spin out of balance,,,its an easy fix if you can do the job yourself,
Jan 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Spring detatched from somewhere , water leakage and no spin
The spring is one of the balancers that keeps the motor and drum assembly from moving around too much. It can easily be replaced if you look underneath the machine.
Nov 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Oasis washer model 110.27032600; trapped hidden water
when you tipped the washer was the drain hose still attached? and if so was the drain hose elevated? most top load washers will have an amount of leftover water in the bottom of the tub. with the drain hose off and the washer tipped towards the rear you should lose any excess water. also try to open the top of the agitator to see if there is any water trapped there. hope this helps....
Oct 18, 2009 | Kenmore Washing Machines
Fisher and paykel out of balance switch fault
Machine should reset when it has regained "balance". It is possible the the OOB switch lever is stuck on the tub ( it is under the top in the right corner and hangs parallel to the tub ). Move tub around and reset load. Sometimes the OOB switch get corroded or breaks and needs to be replaced in order to clear the fault. Call F/P.
Jul 18, 2009 | Fisher Paykel EcoSmart GWL15
Washer constantly goes out of balance
1 option is to wind the back feet out so the washer drum will sit more to the front so as it less likly to hit the OOB switch, other thing is that the OOB switch might have corrosion on the inside of it and in this case if it gets moisture inside it during a wash it is more likely to go OOB, so try replacing it this should fix issue, if not replace Motor Control Unit. :)
Feb 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Excessive lateral travel of tub in spin cycle
there are springs that keep tub centered.also some small glides that can wear.most common prop.spring.most models can look thru bottem .the spring that fails most is towards the back,left rear,goes from washer to body.check that out God bless,tom
Jan 03, 2009 | Whirlpool LXR6432JQ Top Load Washer
Washer goes into unbalance mode
Check the springs and spring mounts,(might be broken or not on right), also could be something wrong with the balance switch (where the tub hits the switch).It could be mis aligned or defective. Check the springs first.
May 13, 2007 | Whirlpool AWM6120 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
137 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
