Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Lawn mower will not start
I put fresh fuel in it changed the oil, new spark plug, new air filter and it still wont start?
  • 634 Answers
Check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Posted on Apr 23, 2010
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Toto lawn mower wont start
Hi, do it have a spark plug
Sep 23, 2012 | Garden
WILL NOT START
Ok...time to take her pulse then!
1. Does it have fuel? Look for water in fuel *(check gascan too!)
2. Does it have spark? You need to remove the plug and inspect it. do you see any oil, fuel or even water on the plug tip? You can plug in the sparkplug and dangle it near the metal part of the engine and confirm that the plug makes spark. If it doesnt get another one just to make sure the plug isnt fouled out.
3. Can the engine breathe? Remove the air filter and see if the filter is oil,water or fuel soaked. Is it rusty? Covered in dust, dirt, fuzz or fur?
You can check the engine once you are sure you have spark by putting a splash of fresh gas in the sparkplug hole before putting the plug back in and attempting to start it....leave the air filter off for now. You dont want a bad filter getting in the way right now. If it starts and runs you can put the air filter back on and try to start it....if it wont start....replace filter too!
Good luck and be careful!
Jun 28, 2010 | Briggs & Stratton 190cc 875 Series OHV...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Mar 27, 2009 | Garden
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
701 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
