Question about Compaq Presario X6000 Notebook
Presario x6000 will not power up , power adapter has been replaced, still no power, was watching movie when it overheated and the computer shut down and has not powered up since. any help would be appreciated.
  • 2 more comments
  • hrykare Apr 23, 2010
    The battery was replace a month prior to this happening, yes it was sitting on my lap while watching the movie and could feel the heat, I noticed a smell like a wire may have burned when it happeneed, I have tried the computer with and without the battery and holding the start button to discharge and reserve power before trying to turn it on, when I plug the power adapter in there are three light that come on , on the front , I do not hear any sounds, as soon as I press the power on button the lights all go out immediatley, no fan noise , nothing, there were no issues prior to this, and no new hardware added etc. thank you for what you have replied with so far, I blew out the fans and they were clean ,
  • hrykare Apr 25, 2010
    I went ahead an opened it up and found a ic chip that is fried, it is located near where the battery would be , The board appeared clean and I could find no other parts that looked suspect, I wrote down the numbers off the chip and have done a computer search but no luck finding it nor a schematic for the presario x6000, Here is what was written on the chip P4407 then right below those BE432B , any ideas what this chip does or where one can be found? Thanks for all your help.
  • hrykare Sep 05, 2010
    sorry I havent replied in months of having this problem, bought the new power cord etc etc, tried all the fixes everyone online said to try, nothing worked, so found a non working motherboard on ebay for $20.00 , pulled the suspected chip and transplanted it into the x6000 (easier said than done) and been fine ever since, but am now using with cooling pad underneath, may even add another fan if I can, thanks for all the help.
    sorry its been awhile since I had this problem, but life got in the way, I got the new power cord , same thing, tried most everything people said to do online but still nothing, so found a non working motherboard on ebay for $ 20.00 and pulled the chip I meantioned in my earlier post and transplanted it into the x6000 (easier said than done) and its been fine, I now use a cooling pad also, and also try not to push it too hard with the video movies etc, thanks for all your help.
    Scholar:
  • 97 Answers
Sounds like your heat sink and fan are clogged up with lint and dust. Very common problem but no so easy to resolve if you have never disassembled one. 1st thing to do is shine a flashlight at the fan area. Do you see thru it or does it look obstructed from dust? Before going inside the laptop you can try a vacume and or a can of pressurized air to clear the fins of the heat sink. If it still overheats you need to open the laptop and clean it out. Here is your repair manual. http://h10032.www1.hp.com/ctg/Manual/c00778754.pdf
section 5.19 refers to the fans and disassembly instructions. Good luck! Phil. P.S. The fans are on the bottom so if you have it in your lap or on a table it will overheat from lack of air. Set the laptop on two books spread apart to see if it works. If this works buy a laptop cooling pad they work great.
Posted on Apr 23, 2010
  • hunterking Apr 26, 2010
    As Kornho said the board has to be replaced. Replacing the chip is hard enough with the right tools, but how do you know what caused it to blow in the first place? There may be other components that have also been damaged. Watch EBay and you can probably pick up a unit with a good board fairly cheap. Good Luck
  • 781 Answers
Ok so power adapter has been ruled out as the problem.
lets rule out the battery pack as the next usual suspect. simply deattach the battery and plug the computer to the ac with the adapter and see if the computer turns on. if it does, replace the battery
do you get any beep codes by any chance? do you see any lights on the computer itself?
how do you know that it overheated? did you see smoke? where you watching the movie while the bottom of the computer was not being ventilated?
if no lights come on your problem is more serious as it could be the a blown capacitor in your motherboard or a loose power adapter (which a computer repairshop /electrician could replace or resold for you for a fee) or the cpu that has gone out in which case means you need to replace your computer and sell the laptop for parts in kijiji.
  • Francisco Cortes
    Francisco Cortes Apr 24, 2010
    a smell, may be a capacitor that got blown, chances are you motherboard needs replacement. unless you have the tools and know how to change a capacitor, your last resort at this point is an actual repair shop..
  • Francisco Cortes
    Francisco Cortes Apr 25, 2010
    unless you don't mind chatting with someone in china which may sell you the part needed (simple google p4407 and do a RFQ),
    you are probably better off purchasing the whole motherboard, find it here
    good luck!
Compaq v6211au overheating and suddenly shutting down
you need too replace your power supply youn can get a new one from staples or ebay..
Apr 14, 2011 | Compaq Presario V6211AU AC Adapter - 65...
HP Pavilion zv6000 power issue. My laptop fan kicks into high gear whenever the adapter is plugged in. Frequently it suddenly shuts off completely to keep itself from overheating. If I use battery-only...
the PC needs to be cleaned,every year or it will overheat.
lint packs up.
what is the ADAPTeR, we cant guess them. ever.
aH the AC power pack is the ADAPTER?
i bet the battery goes dead with no adapter right
so the acid test is this
no battery run on the adapter
if that fails, the adapte is wrong or dead. or weak
1: wrong size 65w or 100w. less never.
2: wrong voltage ,19vdc is correct for HP. not 12,
3: the jack on the mobo for 19v is cracked ,common on some
i never buy PC with this part , I buy Elitebooks that cure that horror.
what happens is you flex cable.
and the jack flexes and then the solder joint crack
all do, its one bad horror. (mine uses a anti crack flex cable inside)
http://www.ebay.com/itm/DC-POWER-JACK-IN-HP-ZD8000-ZV6000-COMPAQ-R4000-X6000-MOTHERBOARD-SOCKET-CHARGE-/271259462380?hash=item3f2852eaec:g:C8MAAOxy9LxSDsly
Aug 04, 2017 | HP Pavilion zv6000 Notebook
I have a compaq presario x6000. every time i place the laptop on my bed and turn it on it cuts off within 5 minutes. but when I place it on a desk and turn it on it does not cut off. do not understand why...
The reason is because when the laptop is placed on the bed the cooling vents are blocked and the CPU overheats and shuts down. When the laptop os placed on a flat surface there is sufficient clearance between the bottom of the laptop and the flat surface of the desk to provide sufficient air circulation.
If you wish to use the laptop in bed then place the laptop on a flat surface and not let the bed clothes cover the laptop's cooling vents.
Aug 12, 2010 | Compaq Presario X6000 Notebook
I have Presario X6000 keyboard problems
it is doing so because of the faulty keyboard ..pls see the backspace button is stuck or not ..you can clean the keyboard by removing it ..
Thank You
Dec 07, 2009 | Compaq Presario X6000 Notebook
My presario a900 14 months old used for internet only so no havey load some times watched a movie, is over heating. my ''speedfan'' progran indicate temps at 80 to 85 I try to download everst and it took...
It looks like your system is dangerously overheating!!!! a standard machine should be around 20-40 what size is the video card? how many fans in machine? what is speed of CPU?
Jul 08, 2009 | HP Compaq Presario CQ50-140US NoteBook
Computer shuts down
Your computer is most likely overheating.
Make sure it is positioned so that none of the vents are blocked on the unit.
Check it with your hand to see if it's overheating, make sure dust is not blocking the vents.
If the issue persists, could be software or a failed cooling system on the unit.
Jun 28, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario X6000 PC Notebook power connector gone bad
Welcome to FIXYA
a common problem for all laptops when you plug in and remove it alot there is not recall on any laptop i know of for this problem and your repair man is right you will need to take it in and have it repaired ...as for where no clue i do know if you call the company to have them fix it they will but will cost you and might take a few weeks to get it back
hope this helped out have a good day :)
Jul 16, 2008 | Compaq Presario X6000 Notebook
Compaq Presario X6000 Notebook Logo
224 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
