Question about GE WBSR3140DW Top Load Washer
Problems w washer
My ge washer the cold wont work anymore
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with that problem...
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on Apr 23, 2010
Does the GE a/c asr05lcs1 take water
No you do not add water to A/C unit,its job is to remove moisture from the air,so make sure it is draining out the back ,if it wont blow cold after that get rid of it ac units are not to expensev anymore good luck
Jul 21, 2012 | GE ASR05LC Air Conditioner
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Not blowing cold air anymore
Possibly dirty evaporator coil or condenser coil. Maybe dirty filters. Also could be low on refrigerant charge.
May 17, 2010 | GE AJCQ08ACB Air Conditioner
My 1998 GE washer was spinning off balance, i went to shut it off but it stopped spinning and now wont spin anymore in spin cycle
Sounds like the balance weights come off, and when this happens there is a switch that get tripped to stop it destroying itself, problem must be remedied before it will restart
Jan 31, 2010 | Washing Machines
Can I use only cold water with my GE front load washer
Just used the cold water and plugged the hit water tube. It worked.
Mar 18, 2009 | GE Profile WPXH214F
GE washer
replace the water inlet valve
Jun 10, 2008 | GE WBSR3140DW Top Load Washer
GE washer
if you are only getting hot water on warm setting possible bad inlet valve cold side ck wiring first just to be sure wire to cold side not loose
Jun 08, 2008 | GE WHRE5260E Top Load Washer
GE Washer
have they checked the door lid switch?..it could be intermittent also because if the switch is not close, it would not drain and spin anymore. try to bypass the switch temporarily by shorting it out then use it . becarefull because you can now open the door while it is spinning ad it is very dangerous.
Feb 17, 2008 | GE WPRB9110WH Top Load Washer
GE Washer wbsr3140d5ww water problem
Hello Chad
Welcome
Sounds like the cold water knob or switch is not switching and may be faulty.
I have a problem with my washer
For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine
The cold water does work though because if I change the washer to a later cycle cold water comes out just fine.
So it almost seems like its the timer knob
any ideas?
Thanks
Please remember to leave a rating
Jun 04, 2007 | GE WBSR3140D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
