Toshiba rd-kx50 recorder error 3B - HDMI doesn't recognize tv
I have a toshiba rd-kx50 recorder that works great except that every time I turn it on I get an ERR-3B (HDMI connection problem) even when the tv is already on. If I cycle the tv through the HDMI inputs (sometimes 2 or 3 times) then it works, but it's a hassle. Is there a way to avoid this besides leaving it on 24-7 or wearing out the tv remote button?
  • hotrod10 Apr 21, 2014
    Found a firmware update from Toshiba, got it from Toshiba on a disc, followed the directions to the letter, and it "bricked" my machine. DO NOT try to install the firmware update
WOW another person that kept the rd-kx50, Welcome brother or sister to the fold..lol.
I had that problem a couple of times, I just remove the hdmi cable while the tv and recorder are off, and then connect it once it's back on.
It's a pain to do this, but you could just use the component cables and not worry about the issue (at a slight cost of picture quality)
Posted on May 12, 2010
Testimonial: "If you still have the this device, see my warning in the comments section."
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-85DTSB recorder remote control wont work, getting DR-Off when pressing any buttons?????
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Oct 01, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
DVR Set to DR-2, can't set it back to DR-1.
Just unplug the DVD cord from the power source and re-fix it after a minute or so. It's so simple. Please let me know if it works for u. setornam123@yahoo.com
Sep 26, 2010 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
Dec 19, 2009 | Computers & Internet
Hi, I have a toshiba RD-XS52 that requires a firmware update before HDMI will work with newer model TV. Have tried to download and run update link provided by tosiba with 10 pouched discs. Any thoughts?
I tried the firmware found on Toshiba Canada website, it doesn't work. I believe the US version of RD-XS52 firmware is not upgradeable. The site said the firmware is for RD-XS52SC. You guys got it to work?
Jan 19, 2009 | Toshiba RD-XS52 DVD Recorder
Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
May 07, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Remote control
Search for toshiba P000416560 on google. Many companies sell this remote. It'll cost about $35.00 or so.
Mar 01, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Toshiba DVD recorder problem
Generally, this problem is caused by bad sectors or other problems on the hard drive and can be resolved by going into the setup menu and re-formatting the hard drive. Of course, all recordings on the hard drive will be erased, so spin them off to dvd first. Be sure to have unplugged and replugged the unit immediately prior to going into the setup menu (don't try to record anything). If this doesn't work, no-one will repair this unit locally, as it must be returned to Toshiba's(TACP) depot for repair. Best of luck.
Feb 02, 2007 | Toshiba RD-XS52 DVD Recorder
Televison & Video Logo
285 people viewed this question
Top Televison & Video Experts
