Question about Troy Bilt Tb70ss Gas Trimmer
Changed fuel line on my troy-bilt gas trimmer wichone goes where
  • 4 Answers
The fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Posted on Apr 24, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Wh does my electric hedge trimmer shuts off when I angle it.
It is not getting enough fuel for some reason. Either water got it, the gas is bad, the line may have a hole in it, ect. Check fuel/fuel tank
Jul 29, 2014 | Troy-Bilt Troy Bilt Tb24htb 24" Dual...
Troy built trimmer fuel lines
normally the one nearest to fuel pump /primeer bulb is the inlet and the lower one is return
WHY can't you just connect hose to one and pump primer bulb to see what direction it goes ?
Jul 28, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
How do i fix my flooded TB32 EC troy bilt weed eater?
be sure fuel filter is on the primary fuel line in the tank.check primer bulb and fuel lines.also check fuel tank cap.vented cap may be stopped up
Sep 10, 2012 | M T D Southwest Inc Troy-Bilt TB32EC...
I have a Troy Bilt 4 cycle trimmer, TB475SS. The small fuel line in the gas tank has come off. I is about 6" long with a filter at the end. The trimmer can not **** any gas. How can I reattach it...
i would suggest to change all you fuel lines. troybilt uses specific fuel lines that they sell. you cant use your regular tygon fuel lines.
Sep 23, 2011 | Troy Garden
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My troy-bilt TB425CS gas string trimmer gas lines have gone away. In replacing those lines how far into the tank do they go?
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Aug 14, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Where is the gas filter located on a troy bilt trimmer?
The fuel filter is inside the fuel tank. Replace the fuel filter. Do not clean it.
Apr 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troy Bilt Tb70ss Gas Trimmer Logo
1,084 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
