I have a HP 2605 DN its has been asking for Black toner, it is a color machine. The Cartridge has been replaced twice with a new one. It still has en error to replace the the black toner, and i cannot use the printer it wont print , what can be the cause Thanks
  • 776 Answers
In this case the issue looks like an issue with the cartridge lockers.
Please clean the cartridge contacts and HV pins in printer.
YOu might want to try out in this manner:
In the printers menu, under system set up, then print quality, then replace supplies there you can choose override out.
Please print a status page and check status for the cartridges, if the printer don't prints in override mode there is a broken cartidge locker. In that case, remove all toner cartridges and check the lockers by moving cartridgedoor in and out.
Posted on Apr 23, 2010
We have an HP Color Laserjet 2840 printer in our office. We were low on our black ink drum, bought a new drum and installed it. Copies are coming out perfectly but the "replace black...
The 2840 is a slightly different sort of machine when it comes to supplies. There is a main imaging drum unit which works for all four colors, and then there of course are the 4 colors. If the unit was asking for a drum unit then you should have instaled a Q3964A. It is entirely possible that your drum unit and black cartridge both expired at the same time, in which case, you need a black toner cartridge now.
Jul 28, 2011 | HP LaserJet 2840 All-In-One Printer
My Hp Color laserjet 2605 was not working some colors (yellow,megeanta) so how to resolve this problem ? all color tones are new ! i would pinted test page black and cyan was ok
This is a common problem with this model of printer. The scanner optic degeneration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta and yellow toner cartridges, red tones are the first to show fading. Colors shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a compliant technician to resolve this issue as it means dismantling your printer and cleaning the mirrors and lenses in the optic section to fix the problem.
Aug 09, 2010 | HP Color LaserJet 2600n Printer
This machine ran out of toner today, but didn't give a local notification that it was low. I have tried to find the setting to enable this notification via the printer's web page, but am unable to find it....
Thank you for contacting FixYa with your printer inquiry.
HP toner cartridges for this printer have an embedded chip built into the cartridge that prompts "Low Toner" message locally and will broadcast through its WEB server. Non HP Toner Cartridges or Refilled HP Toner Cartridges will no longer have the chip enabled to generate this message. You can continue to print but the toner level status will not be generated.
Solutions; Purchase new HP Toner cartridge's from reliable source.
Try a third party replacement chip"
http://cgi.ebay.co.uk/HP-LaserJet-P4015-P4015n-dn-Toner-Reset-Chip-CC364X-64X-/310239780829
http://www.octopus-office.de/en/shop/details/c/toner-powder-hp-p-4014-4015-4515/p/reset-chip-hp-p-4014-4015-4515-black-toner-chip/
Hope this helps. Please keep us updated and remember to rate this answer.
May 19, 2010 | HP LaserJet P4015N Printer
My HP 2600N doesn't print the red and I tried to use 3 new toner but it still don't work. It's not the toner problem and it's the printer. My HP warranted is expire. What should I do? Thanks!
HIgh probablility that the DC Controller has had it. This is an increasingly common fault with the HP1600, 2600, 2605, Canon LBP 5000 and 5100 machines all based on the same engine. The DC Controller puts the charge on the cartridges. When it fails the Magenta cartridge is the first affected and the result is - No Magenta ( reds, oranges, violets etc.) The DC controller must be replaced.
Dec 04, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 2605. The printer indicates that it is low on toner by a Toner Beaker Pictogram, even though have put in 2 different OEM Black Toner Cartridges
I've seen this before.
Do the test print, from the printer's built in menu system, that shows the cartridge serial number.
You'll find that the serial numbers of the cartridges that produce this 'problem' are a different length than ones that don't.
There is ar firmware update ecommended for HP Color LaserJet 2605 series printers that have a version prior to 20071108. This utility updates the printer firmware version to 20071108. Your printer's current firmware version can be found on the Self Test/Configuration Page which can be printed from the printer's Reports menu.
Here's the link to it
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=uk&prodTypeId=18972&prodSeriesId=1140727&prodNameId=1140730&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ly-40741-3
Oct 02, 2009 | HP Color LaserJet 2600n Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Changed toner, replacement hp cartridges, all four at one time, colors are not mixing correctly. black prints good alone
you have to replace all the four cartridges at the same time,, black need not be replaced if it is working well.. thank you,., plz rate me,,
Jul 05, 2009 | HP Laserjet 2605 Printer
New Black Cartrige
plz try with another cartridge
Jul 01, 2008 | HP Color LaserJet 2600n Printer
HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Oct 07, 2007 | HP Color LaserJet 2600n Printer
26 people viewed this question
k24674
jasbo
jasbo
