Question about Dryers
After the door is closed on my maytag neptune gas dryer,the ignitor glows and the gas valve opens once and after the valve closes the ignitor works but the valve will not reopen. what could be causing this?
  • Dryers Master
  • 43,501 Answers
The ignitor is going bad...yeah, I know it is glowing, but there is more o it then that,,,
If you have a gas dryer..
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 23, 2010
Maytag Gas Dryer, 18 years old. Vents are clean through the entire system. The thermal igniter/coupler glows for a few seconds and sometimes ignites the gas and it's fine. However, sometimes it glows and...
Hello- You will need to have the Coils replaced, they are not holding the valve open consistently, it is a fairly common issue and presents itself as you describe. The parts are fairly inexpensive but you should have a Tech out to change them for you. These are great dryers and I would have the Tech look through it while it's opened up...drum wheels and belt should be checked for ware. Hope this helps, best regards.
Sep 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do I get to the ignitor
unplug the unit
open the door locate thee four screws and remove
remove the door and the front panel
you will now have access to the ignitor
be careful it is very fragile
iif the ignitor glos it is ok
you can test it by closeing the door with the frame off and turn the unit on
does it glow? if no more than likley ignitor is bad
if it glows and no flame you have bad ignitor coils
let me know if this helps
Aug 24, 2010 | Maytag Neptune MDG5500AW Gas Dryer
May Tag Gas Dryer Model MDG3000AWW - Dry works but no heat, more dry/ less dry lights flashing. Whats wrong? How do I get heat again?
it is either your glow coil or it is your ignitor
open the door and remove the four screws
take the front panel off.
leave the door attached so you can test the dryer
be very careful not to touch any wires while you are doing this
now close the door and turn the dryer on
does the ignitor turn on?
if yes that is good
does the ignitor glow and no flame?
sometimes it will take a minute to show it's problem
if the ignitor glows and no flame replace your ignitor coils
make sure to turn the power off when replaceing the coils
Aug 24, 2010 | Maytag Dryers
Dear Sir/Madam: I was reading some instruction online on how to troubleshoot a gas dryer and I got confused on two items about the flame/radiant sensor operations. One described it as light sensor and it...
If your dryer is not lighting you should first ck to see if the ignitor is glowing if it is there is a heat sensor looks like a big wire 1/8th inch around that is near the ignitor that senses the heat and then the gas valve kicks on. There should be an access plate to see the glowing ignitor with it all hooked up. If you are set on cking it without hooking it up to the gas put your hand on the gas valve and when the ignitor heats up and the sensor tells the gas valve to turn on you will feel a click. The normal problem is a bad ignitor. If its the glow type its obviouse if its the sparking type you will hear it popping if its working. I believe yours is a glow type. good luck
Aug 16, 2010 | Dryers
I have a maytag neptune gas dryer and out of a sudden it stopped heating. excellent air flow but no heat
OPEN THE DOOR, TAKE OFF THE FOUR SCREWS, REMOVE PANEL. CLOSE DOOR AND TURN ON MACHINE. LOOK UNDER AND YOU WILL SEE THE BURNER ASSEMBLY. IF THE IGNITOR DOES NOT GLOW, YOU HAVE A BLOWN THERMAL FUSE. IF IT GLOWS BUT WOULD NOT LIGHT UP, YOU HAVE A BAD RADIANT SENSOR OR YOUR HIGH LIMIT THERMOSTAT SHORTED OUT. IF YOUR THERMOSTAT HAS A RESET BUTTON, PUSH IT IN AND YOU WILL HEAR A CLICK, THAT WILL SOLVE YOUR PROBLEM. GOOD LUCK
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THRU IT IF NEEDED.
Jan 16, 2010 | Maytag Dryers
Dryer will not heat
On the maytag gas dryer there can be a couple of problems.
1) there is a safty switch on the modor start switch that has to close befor the gas can come on.
2) There are safty coiles on top of the gas valve. Sometimes one of these may be burnt out. You have to check the resistance of each coil.
3) There is a light sencor on top of the burner funnel( a little black box with two wires comming out of it.) This can malfunction some times.
Not always an easy solution. Lots to check.
Dec 22, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer runs but doesn't heat up
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Neptune won't dry clothes -
I would replace the solenoids. The gas valve is not fully opening. The glow bar may be failing but the coils on the valve are in need of replacing..
Eric
Sep 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Lights once then not again
Hot Surface ('Glow Bar') Ignition System glow-amin.60x20.gif (most common)
This is the most popular system currently in use and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve. What happens in this style control system is that the thermostat or electronic control supplies power to the oven ignitor and gas valve which are connected in series (one after the other). As power flows through the ignitor it heats and allows a specific amount of current to flow to the oven valve which is in the same circuit. If the oven valve senses the proper current flow, it opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it.
Jul 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW Not Heating
The coils are the #1 failure in gas dryers, below is a description of how they work. This excerpt from; www.repairclinic.com.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Jul 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Dryers Experts
