Question about Casio G'zOne Boulder Cell Phone
My main screen has gone white. Can it be fixed cheaply or by me?
  • Casio Master
  • 6,993 Answers
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Posted on Apr 23, 2010
I have a Mitsubishi WD65733 it had the white dots all over the screen. I replaced the DLP chip and that fixed it for a few minutes then the screen went bright white. Now when I turn it on the screen is...
Hello, the main chip in the "light engine" has gone bad. Mitsubishi had a program that they were sending out the chip at no charge, but wouldn't pay the labor of changing it. I don't know if they still have that program going, but you might want to contact them. tks
Nov 05, 2013 | Televison & Video
My samsung U900 screen has gone funny. All I can see is a white bar with SAMSUNG written across the middle and everything else is a black and white fuzzy snowstorm... The phone works, but I cannot see what...
hi will. unfortunately the flexcircuit cable has gone faulty. the flex cable connects your screen to the main board, so the only fix is to have it replaced. take it to your local service centre
nick
Sep 02, 2010 | Samsung U900 Soul Cellular Phone
How to fix a ds light when the screen flashes for a second and turned off but the battery light is green
This indicates that one of the lcd screens has gone. Depending on which screen flashes it is the opposite screen (the one that doesnt flash) that has gone. Screens can be bought off of ebay very cheaply and are relatively easy to fit. There are some good guides on the internet explaining step by step how to fit new screens.
Hope this helps
Aug 01, 2010 | Nintendo DS Lite Black Console
I had 2 blackberry 9700 s. One has a broken screen, the other has a bad speaker receiver. I took the screen from the blackberry that had a good screen and placed it in the blackberry with the good speaker...
The white screen is a ribbon cable issue.
You have had both phones apart so you know what I am talking about when I say ribbon cable?
It's the flexi cable that links the screen to the main body of the phone.
CHeck it is not damaged and check it is connected correctly.
You will see lots of people with all makes and models of mobile phones have this same issue and 80-90% are caused by a pesky flexible cable.
You may find a replacement fairly cheaply on Ebay if you have damaged both cables. They are delicate so take care when handling.
Jul 23, 2010 | RIM BlackBerry Bold 9700 Smartphone
My screen has gone completely white and yet still
hello,
the screen has gone completely white because there is a problem from the connection linking the screen to the board.
try to adjust the screen to the end and see what will happen.
if it does the same, that means you have to fix the flex of the laptop.
the flex is the part that links the board to the screen.
take care
Jun 07, 2010 | Computers & Internet
I have a Westinghouse LCD tv model SK-19H210S, The screen has gone white is this fixable?
Can be caused by a couple of things. LCD screen failure or main board failure. Either one would not be a cheap fix if at all possible.
Apr 14, 2010 | Westinghouse Televison & Video
Sidekick id screen
Seems you need a new Lcd assembly i can provide you with one very cheaply please contact me at sk3repair@yahoo.com I can sen you a new Lcd or u can send me the phone for repair
Jul 21, 2008 | T-Mobile Sidekick ID Cellular Phone
White Sreen
unfortunately it would appear to be a CCD or main board failure.
If the camera is out of warranty (as this should be covered) my best suggestion is to pick up one off ebay with a broken screen and put your screen in it, broken screens are common on these cameras so they go quite cheaply, far cheaper than kodak would charge for repair and the swap is easy.
There are several searchs to try "parts v1003" "spares v1003" "Faulty v1003" "repair v1003"
Best of luck
May 26, 2008 | Kodak EasyShare C513 Digital Camera
Blank white screen
when switched on the phone,my phone screen only show nokia and i want to turn off cant. how to solve this problem?
Feb 08, 2008 | Nokia N76 Cellular Phone
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Casio G'zOne Boulder Cell Phone Logo
630 people viewed this question
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
