Question about Garden
Craftsman blower fuel bulb wont pump up-replaced carb, lines & filter. same results, if starts -starves for fuel
  • 634 Answers
The fuel bulb may have dirt contaminating inside, the bulb should be replaced and flush the lines with carburetor cleaner spray to remove any dirt.
Posted on Apr 23, 2010
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Craftsman trimmer 25cc
Diaphrams can be tricky sometimes...seating can be irritating. If carb disassembled and cleaned out...might have to check adjustments. Make sure screw didn't get loose. I had one do that before when governor broke.
Apr 21, 2014 | Craftsman Convertible 25cc. Gas Line...
Wont prime up
I have seen a couple of different things cause this... Are the fuel lines hooked up and not split and fuel filter routed right in tank.(hanging freely touching bottom of tank lying flat) next if your carb has adj. screws H &L I have seen when the H is cranked snug (lean) that primer won't work right. Last but not least your Needle inlet valve is stuck shut and or the fuel pump diaphram little tabs are not sealing off chambers in carb on fuel pump side. make sure your fuel lines are properly hooked up to the right spots. when you push primer bulb it should squirt gas into the fuel tank, then when you release it ,it should draw fuel from the tank through the filter and thru the carb and then out to tank.
Nov 18, 2011 | Homelite Carburetor Trimmer Blower...
Both lines from carb. are cracked..358.797550 craftsman blower/vac how hard is it to replace the 2 lines and I know one is for fuel, what is the other line for and where does it connect to from the carb. ...
Thin line is the fuel intake and is attached to the fuel filter. The other is the return, and should be placed on the tube below the primer bulb of the carburetor.
Sep 13, 2011 | Craftsman 4 Cycle Blower/Vac
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Leaf blower wont go into full speed when you shift the throttle. changed the plug, gas and checked the filter. Do these things have a fuel filter?
Yes, there is a small filter at the end of the pick up line. However, you did not specify whether you are "starving" for fuel, indicating a filter that is clogging. Most likely, you have a dirty air filter, it may look clean but is not letting in enough air. I believe there is a carb adjustment available on that engine, if you elect to adjust it, keep the current reference marked, and make adjustments in 1/8 turns, no more than 1/2 run in, or 1/2 turn out.
Apr 15, 2010 | Craftsman 4 Cycle Blower/Vac
CRAFTMAN LEAF BLOWER WONT START
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
The air filter is clean, however the fuel ine is brittle and the fuel filter isnt attached as a result. I have removed the carb and blew it out with a can of air. I did notice that the carb gasket is...
If you are looking to replace fuel lines, fuel filter; you may also need to go ahead and rebuild the carburetor. The diaphragms in the carburetor may be worn out and may not be able to pump fuel.
Good Day.
Oct 09, 2009 | Craftsman Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
