Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a troy Built riding lawn mower with a Briggs and Stratton motor. I have replaced the air filter and the spark plug and the engine surges and then shuts off. I have noticed that the plug has been bent down almost touching the electrode on the plug. I am using the right plug RC12YC. The model of the enngine is 311777-0148-E1. What could be wrong??
  • daveyasc Apr 23, 2010
    What is causing the spark plug to be damaged? The answer you gave me doesn't seem to fit the problem. The engine I have is a 17hp Intek. What other solutions might you have?
  • daveyasc Apr 29, 2010
    This was a waste of money. I did exactly what you said and the same results no change in performance at all. It still surges and eventually will stall. The only way around it is to play around with the throttle and put it in a choke and then gently backoff so it runs smoothly but this is not right. Any other suggestions? Ron
5 Suggested Answers
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 24 Answers
SOURCE: Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Posted on Jun 30, 2010
SOURCE: I have a Briggs & stratton 18hp ohv riding
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Posted on Jul 18, 2010
philwalker78
  • 608 Answers
SOURCE: I have a husqvarna riding
Hi, check the valve clearances, regards Phil.
Posted on Jul 24, 2011
My troy built briggs and stratton 22hp riding lawn mower when I engage it makes a clunk sound but the pulleys and blades wont turn
sounds like you have something stuck on the blades. if not check to see if you can turn the blades by hand all the way around. its possible the spindle bearings locked up. (with the engine off)
Jun 14, 2016 | Troy Garden
Wiring diagram for a 250cc 11.50 briggs and stratton engine on a troy built wood chipper
http://www.briggsandstratton.com/us/en/support/faqs/horizontal-shaft-replacement-engine-specifications
Jul 11, 2014 | Parks Optical 13.5hp Briggs And Stratton...
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
White smoke and oil spewing out of troy built briggs and stratton 650 series 190cc mower
Check your oil level. If it is way over full, smell it to see if it smells like gasoline. If it does, you have a carburetor leaking gas into the engine crankcase. If you recently had the mower over on its side for blade changing or inspection, you have gotten oil up on top of the piston and it should burn off in a few minutes of running. Check your air filter to see if it is soaked with oil, replace it if it is.
Sep 19, 2009 | Briggs & Stratton Garden
Need a fuel tank for a Troy Bilt mower
You won't find the fuel tank on MTD's site because it is part of the engine. MTD makes the mower, Briggs and Stratton makes the engine. Get the model and type number off the engine and search Briggs and Stratton's site or post it here and I will tell you the part #. Dwain
May 21, 2009 | Troy Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
275 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
