Question about Exercise & Fitness
Code FF on a Proform 695 LT
Code FF I have a Proform 695 LT Treadmill and when I plugged it in, the code FF was on the console display. I tried unplugging it and resetting, but I am not getting any power. What does that code mean?
    President:
  • 832 Answers
Upper electronics have failed and will need replaced depending on how much you spent on the unit it may not be worth it. Go on iconfitness.com website go to customer service then replacement parts input manufacturer then Model Name
Posted on Apr 24, 2010
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 03, 2013 | Proform 695 LT Treadmill
Need new proform treadmill 695 lt motor
go to www.fitnessrepairparts.com and God bless youMeasure the input voltage to the motor if there are voltage , the motor is faulty. mesuare the output voltage from control motor board, if there are NOT the control board is faulty.see the block diagram.God bless youac4388bf-31eb-4f87-ad43-9c0c10d012bc.gif2e4eb1b3-5071-4c47-9080-6b4922436639.jpg
Apr 05, 2013 | Proform 695 LT Treadmill
The board will light up but thats all it will do..695 LT
1) replace batteries with new one preferible Hybrid rayovac rechargeable. with the same polarity,clean the contacts batteries
2) tight the ribbon cable inside for keypad display board.
3) adjust the REED swtich, see the diagram, test the switch for open or faulty, clean it, and tight the connector.
God bless you
Jan 07, 2013 | Proform 695 LT Treadmill
Has an FF on the display sreen and it wont start
Please LUBE the Deck belt, this happen because the lack of maintenance according with the schedule.Maybe you have a deck wron and need replace see diagram
2= Lube the Rollers bearing very well
3= Adjust the Reed switch , clean it,tight the wires connector, see the diagram
4= measure the voltage input motor, if there are the motor need REPAIR.
5= Measure the output voltage board, for input voltage motor, if there ARE NOT the board is faulty.
see the block.
God bless you
Jul 29, 2012 | Proform 695 LT Treadmill
Is there a weight restriction ?
It is not a restriction. It is a recommended limit of 300 lbs. See ProForm 695 LT Treadmill
If you weigh more than the limit, the machine will feel, and be, unstable. You could also harm the motor over time.
Dec 28, 2010 | Proform 695 LT Treadmill
FF in display
Sorry to say that the upper electronics has failed and need to be replaced. Go to Iconservice.com click on parts replacement the input Proform then just 695 they will your treadmill on the list. In my opinion replace the treadmill if the repair is going to be more than 1/2 of what you paid for the unit
101 CONSOLE 1 $340.27
Sep 29, 2010 | Proform 695 LT Treadmill
Exercise & Fitness Logo
731 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
