Question about GE Spacemaker JVM1640SJ Microwave Oven
What is the recommended clearance between spacemaker microwave oven and range top
  • 670 Answers
30 inch minum from the cooking surface to the cabinet above. See this link for installation instructions and more specifications.
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Posted on Apr 23, 2010
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Spacemaker profile ge over the range microwave displays f3 and buttons will not do anything.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 22, 2010 | GE Profile Spacemaker Over-the-Range...
My ge over the range spacemaker microwave keeps blowing fuses after a few seconds cook time. This is my second unit within a year and a half with the same problem. Would not recommend this product.
Buy a Microwave Oven after checking it out on http://www.cnet.com .They do a wonderful job rating different products. Check them out and type the product name you are looking for in the search box if not already listed.
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE profile spacemaker microwae oven. The
Yes. You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If yours is a counter top model, you have to remove the outer cover, and the mini-manual will probably be in an envelope inside the wrapper.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Recommended clearance from bottom of microwave to range top
Your installation manual should have given specific height limitations. I'm not sure for your model, but I beleive it's no less than 22". If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 29, 2009 | Microwave Ovens
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
134 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
