Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Changing oil in Biggs and Stratton engine
What kind of oil and how much goes in a 16 HP V Twin LT-166 John Deere lawn mower when changing the filter and mower
  • 2,841 Answers
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Posted on Apr 23, 2010
Where is oil filter on 13.5 briggs
Briggs & Stratton Riding Lawn Mower Engine Oil Filter #696854 ...
? 2:05
https://www.youtube.com/watch?v=QjYmbfGU0qg
Aug 22, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the oil filter on a Briggs and Stratton small ...
Oil Change- Briggs & Stratton 12.5hp Mower - YouTube
? 5:05
https://www.youtube.com/watch?v=udjoD-mW5ig Aug 15, 2012 - Uploaded by Alex's Bikes and Motors
Oil Change- Briggs & Stratton 12.5hp Mower. Alex's Bikes and ... This is going to sound weird, but I can't ...
Oil Filter 492932S - Briggs & Stratton Parts
https://shop.briggsandstratton.com/us/en/parts-and.../oil-and-oil.../oil-filter-492932s Briggs & Stratton oil filters are engineered to keep your Intek, Vanguard OHV and twin cylinder engine running smooth. Save on costly repairs -- order genuine parts today!
oil filter on 13 5 briggs Google Search
Mar 12, 2018 | Briggs Garden
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
I have a charging problem with JD L155c lawn tractor. The battery is new and the voltage to the battery is 12 volts. Not enough to charge the battery. How do I check the ac voltage & what should the...
There are several possible Mowers of the "L" 155 versions.
John Deere LA155 garden tractor lawn mower. These stopped being made in 2010 (they started production in 2009, and so enjoyed a run of 2 years on the assembly lines). The JD LA155 is powered by a Briggs and Stratton 2 cylinder, V twin engine. This engine is 0.656 liters (40 cubic inches) in size and produces 22 hp.
1998 - 2001 LT Series
John Deere LT155 Engine: Kohler 1-cyl gasoline
2006-2006 L155c, This series was produced only in 2006.
Briggs & Stratton gasoline, 2-cylinder air-cooled, 724 cc [44.2ci ], 25 hp
Model 445777-0168E Code 021125YC, these are the engine numbers from a 25 hp twin cylinder, B&S.
Notes on these engines from parts supplier ereplacementparts.com:
Briggs and Stratton 445777-0231-E1 Engine: The proper flywheel part number and/or the alternator magnet size will determine the alternator type or output.
This 25 hp engine has 3 different possible alternators, standard circuit, dual circuit, tri-circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is a multimeter for testing.
  1. Disconnect connector from stator.
  2. Set multimeter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.)
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine ground.
  5. Prepare the lawn tractor for engine start (set parking brake, blade off, etc). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range, or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B. In the picture is a two wire stator connector.
Mar 15, 2015 | Garden
Changing the stator on a 757 ztrak john Deere lawn
1st need to know if it's a briggs vanguard or the kawaisaki model and what Hp they came with 17.5 to 25 hp models why ive even seen them with a honda v-twin on them i do have a youtube video on the briggsvanguard engine disasembly you can view anytime
Oct 03, 2014 | Garden
Mower will not move forward or backward
chang hdrostatic fluid and filter if this dosnt work need hydrostic pump about 200 dollars
Aug 25, 2014 | John Deere Riding Lawn Mower. EZtrak Z425...
What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Apr 13, 2010 | Garden
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,279 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
