My Sony Walkman S series isn't responding to my computer at all it's the most recent version, when I connect it it just says USB device connected, not USB device MTP connected, it works on other computers just not mine.
    President:
  • 1,561 Answers
It could be that your usb port is bad or that your computer does not have the compatible software.
If the sony walkman comes with a software cd, i advice you install the software cd in other for your computer to recognize it.
Take care.
Posted on Apr 23, 2010
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
My Walkman.. is Loading forever and cannot open
1.Try resetting the Walkman by pressing the RESET button located on it. It looks like a small hole. You can use any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
2. Use the supplied USB cable to connect the Walkman to the Computer.
3. Disconnect all other USB devices if you have connected to avoid conflict.
4.Connect the Walkman to the other USB ports on the Computer.
5.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If the issue persists, then connect the Walkman to a different Computer to check whether the issue is with the Computer or the Walkman.
If the issue persists even with different Computer,
If the issue persists you may try using a different compatible USB cable.
Jul 22, 2010 | Sony NWZB133F MP3 Player
Frozen and won't connect to computer
1. Use the supplied USB cable to connect the Walkman to the Computer.
2. Disconnect all other USB devices if you have connected to avoid conflict.
3.Connect the Walkman to the other USB ports on the Computer.
4.Check whether the USB Driver is installed in the Computer or if it is corrupted.
If the issue persists even with different Computer, then try resetting the Walkman by pressing the RESET button located at its bottom. You can use any pin or any sharp pointed object to reset it.
Jul 21, 2010 | Sony Walkman NWZ-S616F MP3 Player
My mp3 player will not conect to my computer i have done it once and it now want let me conect
New Sony NWZ-B133F/BCE Walkman does not show as removable drive
I bought a new Sony NWZ-B133F/BCE Walkman. When I plugged it to the USB the drivers got properly installed, but the player does not show as a removable device or any other device in My Computer.
just follow...be sure your player is connected to pc
go to my computer right click>>properties> IN HARDWARE TAB select device manager>portable audio>right click select update drivers>click next>tick the option let me choose driver for this device>next choose usb mass storage driver from two options click next....
AND U R DONE....
Mar 17, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Sony walkman is not being recognized by XP as a portable device
I remembered that I had another problem with Windows Media 11 that seemed impossible to fix until I found somewhere that uninstalling or rolling back WM11 to the previous version then reinstalling fixed the issue. I decided to give that a try with this problem we're having and sure enough it worked. The Walkman is now recoginized as a Portable Device under Device Manager and in My Computer it is displayed as a Walkman and not a removable disk.
All you have to do is use add/delete software, delete or rollback WM 11 and then either use the Sony disc with WM11 or download a new version. All together it only took a few minutes and I'm back in business. No music or playlists were lost. Try it and let me know if it works for you.
Mar 14, 2009 | Sony Audio Players & Recorders
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
Feb 16, 2009 | Sony Network Walkman NW-E005 MP3 Player
My sony nwz-S616F doesnt transfer songs from pc
Sony NWZ-S616F
Dear holders, I have it and solved all problems which are in discussion. Just read all INFERNAL help, it works! By XP, go to Start-Control Panels-Administrative tools-Computer Management-Device manager (small icon of computer on your left hand side) tab should have “Walkman” or MTP device. Right click on it and go to properties, now before doing anything it should say “Location — —— Location 0 (Walkman)” if not try unplugging the walkman and see if the MTP device you’re looking at is removed from the list, just to make sure it’s the right device we’re looking for.If you’ve confirmed it’s the Walkman, click on the “Driver tab” and click on “Update Driver…”. Then click on the “Install from a list or a specific location (Advanced)” option and click “Next”. Now select the “Don’t search. I will choose the driver to install.” and click next. It should now bring up 2 driver choices, one being “MTP Device” and the other “USB Mass Storage Device”. Select the USB option and select next, it will then install your walkman as a USB storage device and after that’s done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in “My Computer””. Holla for original uploader Inferno!!!
May 08, 2008 | Sony Walkman NWZ-S616F MP3 Player
UPDATE ERROR!
press the reset button at the back of the player ... and that should work for you to try again to update the version.
May 03, 2008 | Sony NW-E507 MP3 Player
Error message
not a solution, but have since found that using all the same hardware I can connect successfully to other pc's that have sonicstage installed. Sony suggested replacing the cable.
Sep 04, 2007 | Sony Network Walkman NW-A1200 MP3 Player
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
