Question about HP Pavilion dv6000z Notebook
Dv6000 will not come on even though the power is on. it starting out shuting down on its on , eventually would not start up
    Scholar:
  • 97 Answers
Usualy when a laptop shuts off on it's own it is due to a hardware issue. The first thing is to blow out the fan and heat sink as it is most probably clogged up and overheating the Processor. You can do your oun diagnostics by doing these steps.. Pull out the battery and try to boot it on ac power. 2. pull out the dvd rom next and try the same. 3. pull out the hard drive and again try to boot it from ac. 4. pull one memory chip at a time and see if it boots. 5. pull out the wi-fi card and do the same. If you go thru all of this and it still will not boot it is something on the motherboard such as a video card or other hardware such as a lose AC Jack. Wiggle the jack while pressing the start button and see if this makes a diffrence. A very common issue with laptop's. If it is the Jack you need to find someone that knows what they are doing or you will have a good door stop! Good Luck Phil please email me and let me know what you find. pmgibs1@verizon.net
Posted on Apr 23, 2010
Car shuts down for no reason while driving is there a solution?
Solenoid holding the bendix drive in mesh have starter checked out
Feb 22, 2015 | 2006 Buick Lucerne
System is producing heat even though its turn all the way down
check if element is grounded to it support or its casing.. some time it will weld ot selt to metal that surronds it, metal distortion appends from heating up and will quite often short to ground and draw power between 1 side of it's imput and discharge it thru the ground keepimg the element supplyed even if the timer/thermotat is shuting propelly the power to the opposite side of the imput line..
Dec 25, 2014 | Dryers
I have a Hp laptop bt it is now not shuting down ie all its light on keep on glowing even on shutting down and also it makes a noise while shuting down or turning it on
remove charger first and remove battery second to try which one causing problem.
if any power source cause the problem that is mean the mainboard or power board inside failed.
good luck.
Nov 21, 2009 | Computers & Internet
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Ok,was starting and then shuting itself off,now it starts, all of the lights are on,but no boot and black screen. for a HP DV6000
most commonly this is called a bios loop, this is due to the fact of a currupted bios command or a damaged cpu. to eliminate bios you must disconnect battery and cmos battery usually located where memory is, cmos battery is a small cable attached to a metal disk. unattach hard drive and restart computer. after restart shut down computer and reattach battery. again start computer without hard drive. if bios screen does not appear and same sceneario occurs then your CPU is fried. If bios screen does appear and you reinstall hard drive and get same boot error then your boot sector of hard drive is gone.
Due to black screen at boot and boot loop I would say ypur cpu is gone.
Sep 27, 2009 | HP Computers & Internet
Dryer is shuting down after twenty minutes cycle time, seems to be overheating.I haved cleaned the vent.
sounds like motor is going bad.eventually it wont start all you will hear is a humm from motor
Mar 05, 2009 | Crosley CDE6000 Electric Dryer
Lenovo booting problem
so u;re saying that the BIOS tests are taking 10 minutes ?! Usually that happenes when the computer shutes down brutally (after power surges, by removing the battery ... by forced shut down). Try doing a BIOS update, and also set it so it will skip some tests or not to do through testing ....
Aug 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
HP Pavilion dv6000z Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
