Question about Hunter Dryers
Fan & lights were working. bulb blew out in flash. replaced all bulbs. fan works. lights do not. what is the problem?
    President:
  • 1,871 Answers
Hello :
It seems that you have problem on LED flicker PCB .
See the pictures to know what I mean :
This must be happened when the lamp blew out .
I hope this will help .
please rate !
Posted on Apr 23, 2010
My Sony KDF50E-2000, the projection light went out, i replaced it, it was working, then the replacement light went out too. Is this something with the TV or do I need to buy another light?
There are a few common causes for rapid bulb failure. If you touched the replacement bulb with your bare skin, oils on your skin will cause hot spots on the glass and can cause quick failure. Also, there are cooling fans that provide cooling for the bulb. If these are not working, bulb failure will occur.
Nov 19, 2015 | Sony KDF-E502000 50" HDTV
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
I have a hunter ceiling fan and the light blew, when it blew then the remote quit working for the light, it still turns the fan on & off but after I replaced the bulb it still will not operate the...
Hello nita... I believe the fact that the remote stopped working is due to a weak battery in the remote. Change that battery and you should be back up and running. Joe
Thanks for choosing Fixya!
Jan 14, 2011 | Hunter 20537 / 20538 The Vista Iron...
The bulb on X1 blew out, I replaced the bulb, the
it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
Aug 10, 2009 | InFocus X1 Multimedia Projector
40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Sony kdf e60a20 - Light is blinking red, blew out the dust on the screens of lampbulb, worked right for a day and a half then started shutting down again, do I need a bulb or the thermal fuse? And if I do...
there could be a few issues.here are a list of things that could go wrong plus part numbers you wanted.
pn# 191002393 thermal fuse
pn# a1085447abarc bulb without housing cheaper
clean fans
other things that cause this:
dmd board or light engine my guess would be bulb and thermal fuse. thanks doctor video
Apr 28, 2008 | Sony KP-53S65 53" Rear Projection...
Turntable, lights and fan inop
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Dryers Logo
148 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
