Question about Asko 1595 Dishwasher
Asko dishwasher starts and immediatly stops
Our power flcked on an off a few times. Now my Asko dishwaser starts and immediatly stops. A squirt of water comes out before it goes off. I cannot make any changes on the board. Did something get fryed or can I just reset something?
  • 6 more comments
  • myguinesssto Apr 23, 2010
    Hi, It is set to normal load. the board does not respond at all. If I depress and release the main power on/off switch, I hear a breif(1 sec) shot of water and then it stops. The indicator just reads (52) minutes.
    Thanks,
    Mike
    Macmarkus,
    I apologize, I should of stated the model. It is a 1504 and the power switch is just below and to the right of the handle.
    Thanks,
    Mike
  • myguinesssto Apr 24, 2010
    Thanks for the info Macmarkus,
    I ordered a new pressure switch but in the mean time I took off the old one and cleaned the contacts(hoping not to have to wash the dishes in the dishwasher) but to no avail. How would I go about bypassing the switch?
    Mike
    Hi Macmarkus, Thanks for your help,your direction where on the mark for by-passing the pressure switch. Unfortunatly the washer is still acting the same way. Is there something else to check?
    Thanks,
    mike
  • myguinesssto Apr 25, 2010
    Hi Macmarkus, Do not worry about it,I am just glad to get help. I tested the valve and it did not stay energized. When you say board think you mean the larger board not the keypad board? I noticed when I removed the control panel for what seems like the hundreth time that on the main control board, facing the front of the washer, there are three blue rectangular boxes on the upper right. The larger one in the middle was hanging by the bottom (pin?). I do not know if I inadvertently did this while removing the panel or if it might be related to the issue I am having.I pushed it back in but I am guessing that it probably was soldered on the other side? What does this tell you?
    Thanks, Mike
  • myguinesssto Apr 26, 2010
    Hi Macmarkus,I took off the board and inspected the back and do not see anything burnt or amiss. I inspected the front side again and found something burnt. Close to the relay that is loose are a series of three plastic, clear rectangular boxes that have a coil of copper wire and a set of contacts in them. The lower one shows a burn spot in the plastic on the contact side. I understand this might call for a new board for most jobs but is not an option for me. I can give you 300 reasons($) why. Do you know if parts like these are available and/or even possible to replace? I would also have to consider whether this is just the component of the board that failed or something else that caused it to fail, making me wonder if it might just happen again.
    Any additional advise is greatly appreciated, also thanks for all your help up to now, even if it does not result in a fixed washer i still enjoyed what I learned. I do not think I will ever grow out of the thrill of taking stuff apart(Safely) and sneaking a peek at how it works.
    Thanks,
    Mike
  • myguinesssto Apr 28, 2010
    Hey Macmarkus, I soldered the first relay and the second I guess is fine( Maybe over time some sparking causes some soot to build up,I just wiped it with a q-tip). Put her back together and she runs fine. What a great feeling when I turned the power on and she fired up!
    Thanks again for your help it is greatly appreciated.
    Mike
  • Mark MacDonald
    Mark MacDonald May 11, 2010
    I'm just asking for a clarification. Do the lndicaters flash or anything when it stops ? Does it fill with water, or does it stop before filling ?
    Let me know and I'll tell you what to look for.
    Macmarkus
  • Asko Master
  • 2,605 Answers
Hi mike, thanks for the clarification. Having this info, I am not sure this model is as the post indicates - "1595". Is it possibly a 1473 or 1474 model with a power button by the door handle ? If so, that is the most common problem with that style Asko. The contacts inside the button make momentary contact & then stop which requires replacing tge switch. Let me know if it is indeed one of these models or confirm what model number it is ok ? Thanks, Macmarkus
Posted on Apr 23, 2010
  • 4 more comments
  • Mark MacDonald
    Mark MacDonald Apr 23, 2010
    Thanks Mike, and no need to apologize, but I will be gracious and accept. I figured it was a model of that era by your discription and the fact that I did work for Asko during that era I saw alot of them.
    Asko actually identify that switch not as a power switch just as they do with the heater switch but rather a "pressure switch" part number 80-530-00. but don't get hung up on terminology. I used to by-pass that switch with my customers approval ( since it stops when opening the door anyway ) but I recommend just replacing the switch if I'm not on site or advising fellow technicians I apprentice etc. besides I think it is only about $30USD. Make sure you turn off the power before trying to change the switch. You should mark the location of the wires on the switch or take a photo or both. Once you loosen the control panel to replace the switch it's a good habit to inspect the wires, control etc. You likely will notice the wires are all covered in black sound deadning material, don't sweat it just be sure the connections are in good condition and if not replace them.
    Let me know if you require any further assistance. Good luck with your repair.
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 24, 2010
    Hi Mike,
    As I mentioned before I'm not a big fan of trying to explain how this is done but I'll try. **turn off the power...I never take that for granted so I check for myself & never allow someone to shut it off for me**
    If you notice there are 4 wires on the power switch. Two of them go to the board identified there ( on board ) as PF2 & PF4, the other 2 on the power switch come from F3 & F4 of the noise filter/capacitor below, which are essentially L1 & N ( hot & neutral ). Locate the wires which come from below to the switch, remove those from the switch and connect them directly to the PF2 & PF4 contacts on the board, they will reach usually without any modification...usually. Sometimes wires have been spliced/repaired previously so I can't say in your case. Make sure you make notes and take pictires so you can re-wire the new switch. Keep the wires you remove from the board wrapped in electrical tape until you replace the switch or remove them all together but keep them just to be safe or you'll need to make new wires later. Please be careful, I don't want you to be hurt or blow the main control board.
    Let me know how you make out. Good luck.
    Macmarkus :)
  • Mark MacDonald
    Hello again Mike,
    I just read over your second post and noticed something you said that I hadn't noticed previously, I think I know why the bypass didn't yield the result I expected. You said "The indicator just reads (52) minutes."
    Oops ! I have to apologize not reading more carefully and if it's not too late cancel the order on the power switch. Knowing the control had a display indicates it did have power going to it, so it has to be internal, and likely the relay going to the water/inlet valve since it gives a squirt of water...meaning the relay closes (energizes) but immediately drop's out by the sound of it.
    If you can, set a meter on the AC voltage setting, place two leads going to the water valve ( either at the board or on the valve leads themselves ) and when you turn it on see if the meter moves at all, even momentarily. If it remains energized but doesn't fill, you need a valve. If it doesn't remain energized, remove the board and inspect the printed circuit side ( green with solder joints & circuit path's ) for burnt solder or pathway's.
    Again I'm sorry I missed that crucial bit of info in your second post, if I hadn't I'd never steer you wrong. Let me know what you find and I will make every effort to help.
    macmarkus :(
  • Mark MacDonald
    Mark MacDonald Apr 25, 2010
    Mike,
    Hello, yes it is that board I was talking about, the same one as the switch by-pass. If the relay was just hanging by a single pin, that isn't good. If you can solder maybe you could repair it. Did you inspect the entire printed circuit board ? If so how did it look ? Let me know what you find I'm very curious, but the user interface/keypad rarely goes bad.
    macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 26, 2010
    Mike, well I have to say I admire your spirit, I guess because I'm of like mind. If I think I can fix something I have to try, hell I'm just curious of what makes thing's tick. I have good news and not so good news, you'll have to decide. The good news is this, usually the relay's itself is at fault and the only thing which "causes" them to fail is the coil or contact's within the relay assembly. Since you can see through these particular relays, you can identify the contacts are indeed burnt up. The bad news...I don't know if you have a local electonic part supply vendor which could fit you with such a relay. I guess your best bet would be to take the entire control to such a part place/supply store and see if it is an option. If you can identify the specs./values on the side of the relay you could also try on-line. You may luck out and find an outfit which can rebuild the control for a reasonable cost. I used to use a place in Ontario, Canada called "National Timer", but I don't even know if they are around anymore that was more than ten years ago.
    Let me know what you find out, As I said I'm curious.
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 28, 2010
    Awesome !
    Hi Mike, I got the email earlier today from fixya that you'd added a comment but hadn't had a chance to look at it until recently ( I'm a big hockey fan and was watching the game ).
    That is great though. It feels good when someone is able to fix a problem that may have otherwise meant $300-$400 minimum or a new machine. Glad to see you stuck to it and saw it through, and yes I know how good that feels when you accomplish/repair something on your own. Congrats !
    Hope it goes another 15yrs. for you...not likely, a few anyway though right, ha ha !
    It's been great working with you, come visit "fixya" in the future for any of your household repair tips and tell your friends and family. Take care Mike.
    Macmarkus :)
Dishwasher Asko 1986 suddenly stopped working
Also is mainly a control board's
Did you have a power outage or power surge?
Need model
Oct 08, 2016 | Asko Dishwashers
Dishwasher won't run
I can help you in getting the resolution, please give me some more details
Apr 06, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
I have an ASKO D1716. Once started, it does not stop. I tried the rinse cycle and it advanced towards to setting 2. But, it continued to operate long past its normal time limit. (I have two of the...
here is a site with the fault codes and how to check for them.
To start the trouble-shooting programme, press the
Temperature selection button five time within 15 seconds. code chart info click on the link below.. Jay
Asko D1796 Use And Care Manual Fault Indications
Feb 10, 2015 | Asko D1716 Built-in Dishwasher
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Power off
Howdy. I suspect a power surge went through your machine and fried its itsy bitsy brain.Its time for a new one unless you have a good supplier and serviceman who will replace the control unit. Get an estimate with a closed top cost before you agree.
Sep 16, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Dishwasher stuck on "drain"
This is a on going problem with asko and they keep jerking everyone around with this defect. I had a repair person come over and used a turkey baster with a 7" rubber hose attached to the end of the baster. He took off the kick plate and inserted the hose end in the overflow tray and pull about of 12 onces of water from the tray. He is a asko repair facility and says it is a comon problem and has made the repair solution on his own as it is easier then taking the hole dishwaser out and tip it on the side just to drain the water. This has been on going for 3 years and each time i called asko it was like i was the only person having such a problem. I now do this every 3 months and the problem is on going. What a piece of junk. Purchased at Marcellas appliances in Schenectady,NY. They also know how to avoid the problem in fact there repair person left out most of the screws so the next time it would take less time to drain the water. DDDDDont buy ASKO. Michael Foote
Aug 02, 2008 | Dishwashers
Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Apr 04, 2008 | Asko Dishwashers
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
May 28, 2007 | Asko 1595 Dishwasher
Dishwashers Logo
447 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
