Question about Eureka WhirlWind Litespeed 5844 Upright Vacuum
Eureka whirlwinde litespeed vacuum - model 5841
I bought a new belt for this vacuum, but cannot find the owners manual to figure out how to change it.
  • mejody2 Jun 13, 2008
    I ma having trouble with the same thing. Any help??
Very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Posted on Jul 24, 2008
Owners manual
Here's a link to the owners manual for your Eureka 5843 Vacuum:
http://www.eureka.com/service/manuals/71496B.pdf
Please be sure to rate a thumbs up if this was helpful! Thank you.
Oct 08, 2011 | Eureka Whirlwind LiteSpeed 5843 Upright...
Eureka Model Whirlwind litespeed. The rotart brush does not turn or rotate. Should it turn or rotate in order to give better suction?
Hello fnintel, yes, if you are using the upright vacuum it should spin, ( the belt likely slipped off, or the brush is clogged with hair and the likes.)
However, if you are using the hose on the vacuum like a shop vac, some models bypass the rotary brush.
Jan 09, 2011 | Eureka Whirlwind Litespeed 5840 Bagless...
I live at zip code 24060 and I need a new belt for my Eureka Whirlwind. Where can buy this?
You can get them at Walmart.
Look on the nameplate and it will tell you which belt too buy
(Probably a "U" belt)
Sep 09, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
How do I replace the belt on my mom's Eureka Whirlwind litespeed 12 amp 15" ?
take the cover off from the bottom there should be clips or screws on the bottom.and work the old belt off and new one on
Aug 12, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
The vacuum roller won't turn but the belt is fine Eureka Whirlwind Litespeed
The belt may look fine but it's probably stretched out. Rubber belts are usually good for about 1 year. The tension of the belt is what allows it to turn under the strain of the carpet. Make sure the brushroll spins freely when held out of the machine. Eureka brushrolls are prone to melt down on the end caps. If that has happened you will need a new one.
May 01, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
How do I change belt for Eureka Whirlwind Lite "Boss" model 450 A
Remove the 4 screws on the yellow top of the vacuum. The yellow plate will pop up exposing the belt and roller.
Jan 20, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
I have to check the belt in the ereka powerline plus. how do I do that?
Below I have listed a link that will open the owners manual that has step by step instructions on how to change the belt. Also I have listed links for the replacement belt you need. Eureka recommends replacing your belt at least every 12 months.Hope this helps you.
Eureka Powerline LiteSpeed Owner's manual
Eureka Powerline LiteSpeed Replacement Belts
Oct 29, 2009 | Eureka Powerline LiteSpeed 5845 Upright...
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Eureka WhirlWind Litespeed 5844 Upright Vacuum Logo
620 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
