Question about Samsung HL-S5087W DLP TV
NEED TO KNW HOW TO REPLACE NO 2 FAN ON A SAMSUNG DLP TV HL-S50786W
    Novelist:
  • 132 Answers
Here is Fan part# BP31-00024A. Search google, find it at various places.
Light engine assembly has to be removed. This involves unplugging various connectors between processing/control chassis on the left side and engine assembly on the right side. Mounting screws on the top and bottom of engine assembly. Then remove light engine assembly completely from the TV. Fan#2 is the lamp cooling fan and is located beside the lamp assembly.
It is not too complicated if you draw a picture of where all the plugs are removed from. If one plug is not put back correctly, unit will not work. Usually a tight fight sliding out the engine. Plastic cable tie-down between the 2 assemblies can be cut and discarded, this makes re-installing light engine considerably easier.
Cheat the cabinet safety switch with tape or stretch connecting wire across it to hold it in "on" position for test after reassembly.
Service cost may be $150-$200 if you don't do it yourself. We do it in most Canada cities.
easyab
Posted on Apr 23, 2010
Is there a manual for samsung dlp tv 5687- location of fan#2
http://www.manualslib.com/manual/510316/Samsung-Hl-S5687w.html
Oct 17, 2015 | Samsung Televison & Video
Samsung DLP TV, model HL67A750A1F fan #3 message then turns itself off
Please check the all fan if working properly if all works fine you have defective board inside behind fan # 3 you need to replace it..
Dec 13, 2011 | Samsung DLP HL-P5663W 56" TV
#2 fan
you need to replace fan #2 , is located next to the lamp is a big fan compared to the other fan you can buy this fans from any electronics place
Nov 12, 2011 | Samsung DLP HL-P5663W 56" TV
I have a Samsung DLP 50" HDTV HLS5086w, and I need to know how to find and remove fan # 2 from inside the TV so I can replace it but when I open up the back I can't see it anywhere. Only fan 1 is...
Fan #2 is the fan that blows air accross the lamp itself. It sits in the far upper right corner covered by a shroud. The ONLY way to remove the fan is to remove the complete light engine itself. I would recommend a technician to do so : )
Jul 27, 2011 | Samsung HL-S5087W DLP TV
#2 fan is not working
search google and ebay
Apr 13, 2010 | Samsung HL-S5087W DLP TV
I have a SamSung HL-S6187W DLP whide screen tv
You need to replace the light tunnel.you will need to remove the lamp and color wheel along with the lamp housing and fan housing to replace it .If you are not comfortable taking things apart you might want a tech.
Nov 30, 2009 | Televison & Video
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp model hl- S5086W making continious humming noise, has nothing to do with volume. Can I replace fan or wheel myself?
Most likely color wheel since most are defective right out of the factory--- someone has a step by step procedure to replace with pictures-- try google- samsung colorwheel -- fun job easy to do!!!
Jan 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp hl-r5667w
This Tv make a lot problems with the color wheel and fan thermostat, lamp cool. Need be check the color wheel first. I am suggested dont have nothing on the back cover ( make hot or not ventilation). More information parts at tritronicsinc.com Thank you
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5087W DLP TV Logo
988 people viewed this question
Jerry Greenberg
Jerry Greenberg
