Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
Trimmer dies when i switch to run - Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
  • 10,865 Answers
Your trimmer carburator is a bit gummed up. Get a bottle of carburator cleaner fuel additive and add it to the fuel in the tank and in the gas can. Be sure to follow the instructions so you get the correct amount of cleaner + gas. In just a few minutes you will notice a huge improvement.
please rate my answer as very helpful. thanks. Joe
Posted on Apr 22, 2010
Poulan weedeater will start but dies when switched to run
Clean the Carburator, Clean out the Carburator Bowl and Float, Change the Spark Plug
Apr 07, 2013 | Craftsman 25cc Gas Line Trimmer
Weed trimmer starts and then dies repeatedly
Yes this could be the cause of the problem, it sounds like a fueling issue, fuel/air mix. Is fuel getting into the cylinder or can it be seen leaking out between the carb and the cylinder.?
Apr 22, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
Stihl line trimmer starts but won't stay running
check to make sure your kill switch is not shorting and you have the right gap from the coil to the flywheel also if the flywheel sheer pin is damaged in the least this will cause a multitude of problems... it is the timing pin and must be in good shape not damaged or sheered ..any way reply to mrdmburns@cableone.net and i will try to help you through this.... DALE good luck and will wait for reply..
Aug 28, 2009 | Garden
Starts on the prime, then dies when switched to run
carb needs to be rebuilt as float needle is sticking not allowing enough fuel through
Jul 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Polan pro pp133
Are you saying that this is a brand new trimmer or is it new to you, used trimmer? You are describing a problem that is typical of a used trimmer.
This is a sign of a clogged gas cap. When the gas cap can't breathe, it chokes out the carburetor.
Try this: The next time you run the trimmer, and it starts to die, loosen the gas cap, it should start running again.
Jim
Jun 22, 2009 | Poulan Garden
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
Homelite trimmer dies every time I squeeze the handle
remove the muffler,disassemble it,you will find a spark arrester screen in it.it is either clogged up with carbon or partially clogged,clean all carbon off,reassemble and try again
May 28, 2009 | Homelite Mighty Lite Lawn Trimmer
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
332 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
