Question about Dell V305w All-In-One R840635AU InkJet Printer
Dell v305 aio printer
Will not recognize new Dell color ink cartridge. says "right cartridge error replace cartridge" .just replaced 2 days ago with new cartridge was working fine tried to print document started getting error message
  • 125 Answers
SOURCE: cannot recognize ink cartridge
I have about 6 canon printers with a 3in 1 using PG40 and CL41. I have never encountered the problem you have. I have looked into some other sites and noticed a number if CLI-8 cartridges being replaced by Canon. I think there are only 2 probable problem areas, he cartridge or the software you are using. I suggest you call up Canon and complain about this problem. Seems like you got the printer 6 months or so ago. You should able to get to do something like replace the printer or cartridges. I'm assuming that you don't refill or have your cartridges refilled so the contact points should not be messy w/ ink. You can try cleaning the contact points on the cartridges and printer. But I'd call Canon and explain to them the situation and see if they can solve your problem. Solve I'm implying is to replace your cartridges or printer. Let me know if this helps.
Posted on Jul 22, 2008
yooperbud
  • 8637 Answers
SOURCE: Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
1alexh
  • 484 Answers
SOURCE: my Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
Posted on May 22, 2009
SOURCE: Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Posted on Jun 17, 2009
SOURCE: dell 924 printer will not recognize photo cartridge
I just bought new ink and my Dell 944 is still telling me I am out of ink and it a new cartridge. How do I tell the computer or printer that?
Posted on Nov 23, 2009
Dell v305 printer allignment problem
Hello Michelle,
You are using Dell Series 9 ink cartridges, correct?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 9 black cartridge and then reseat it. I would then take out the color Dell Series 9 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
It's possible to get a Dell Series 9 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement.
Bhautesh,
Jan 30, 2014 | Dell Computers & Internet
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    My dell v313w printer gives the message that I need to replace cartridges even after I have put in new cartridges
    Are you using Dell Series 21,22 ink cartridges?
    Try Cleaning the Printhead on Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
    Troubleshooting Printhead Problems on the Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
    Open the printer(with the power on) and take out the Dell Series 21, 22 black cartridge and then reseat it. I would then take out the color Dell Series 21, 22 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
    Any error messages?
    Dell Series 21, 22 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
    Dell Series 21. 22 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
    It's possible to get a Dell Series 21, 22 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement or a refund.
    Rick
    Apr 19, 2011 | Dell V313w AllInOne InkJet Printer
    Black cartridge is new. registers low ink level and does not print at all.
    Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
    Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
    If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
    black = black side(left) color = color side(right)
    photo cartridge = black side(left color = color side(right)
    Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
    Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
    It's possible to purchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
    Rick
    Mar 17, 2011 | Dell 962 Photo All-In-One InkJet Printer
    I intalled new ink on my computer and it says to remove tape from cartridge when I all ready did and it will not work
    Rick
    Jan 10, 2011 | Dell 962 Photo All-In-One InkJet Printer
    I have a kodak 5500 aio printer. I replaced the
    Try the following:
    1. Open the printer access door.
    2. Put out both ink cartridges and the printhead.
    3. Let the printer access door open.
    4. Put out all paper.
    5. Pull out the ac adapter at the back of the printer.
    6. Wait 60 sec.
    7. Pull in AC adapter.
    8. Wait 30 sec. then turn on the printer
    9: Wait for the error message: Printer access door open.
    10. Close the printer access door.
    11. Wait for the error message: Printhead is missing.
    12. Open the access door and put in only the printhead and the close the access door.
    13. Wait for the error message: both ink cartridges are missing.
    14. Open access door, put in only the black ink cartridge, then close the acess door.
    15. Wait for the error message: Color ink cartridge is missing.
    16. Open access door, put in the color ink cartridge and then close the access door.
    If the error is solved, do a firmwareupdate right now.
    You can find it here.
    Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Hi there
    Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
    Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
    Hi, Even though I have replaced the black cartridge, I continue to get the message that the ink is empty. I would love some guidance!!!!
    Hi snascent,
    It's possible that you may also need to replace the color ink cartridge. If this is not the case, then the message you're receiving could be due to any of a number of factors:
    1) Make sure that you've removed the sticker and transparent tape from the new cartridge before installing it.
    2) Make sure that the new cartridge is snapped in securely, and that the lid over it is snapped close.
    3) Make sure that the black cartridge is on the left and the color one is on the right (silly as this may seem, it can actually cause problems).
    4) If all of these are done and you still get the same message, you might try powering off and back on.
    5) If it still doesn't recognize the ink, you might have a clogged print nozzle. To clean the print nozzles, click Start Menu > Programs > Dell Printers > Dell Photo AIO Printer 922 > Dell Printer Solution Center. On the "Maintenance" tab, click "Clean to fix horizontal streaks" - then click "Print."
    I hope this helps you - please let me know if you still have problems, or if I can be of any other assistance.
    Kind regards,
    H2H
    Dec 14, 2008 | Dell 922 All-In-One InkJet Printer
    Printer will not print with color cartridge in
    go to dell AIO center
    click maintain/troubleshoot on the top
    under trouble aio problems - click ink levels
    click maintenace tabs
    and then clean print cartridges and align print cartridges. then try printing a test page.
    if this does not work, remove the cartridges and install them again.
    let me know how it goes
    Sep 08, 2007 | Dell Photo 964 All-In-One InkJet Printer
    Dell V305w All-In-One R840635AU InkJet Printer Logo
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
