Question about Panasonic PT-51HX41 51" Rear Projection Television
There is wavy lines in the screen i got most of them out but not all
  • Panasonic Master
  • 3,459 Answers
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
there is wavy lines in the screen i got most of - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 07, 2010
Wavy line on a DLP SAMSUNG 65 INCH PROJECTION TV
Bulb does not do anything but project white light. Wavy lines are a digital board problem. You should have a tech look at it.
May 20, 2015 | Samsung Televison & Video
My samsung projection tv has blue wavy lines on top of screen, I adjusted convergence, the blue will not line up horizontally, is there a inexpensive solution?
It means one of the chips has a bad section inside it, both chips and maybe a resistor near them will have to be replaced, involves soldering as each has about 18 pins soldered in
Check with TVrepairparts.com who sells some kits for this by brand and model number
Dec 09, 2012 | Televison & Video
Wavy snow lines on samsung
are those lines appear in the screen either you hooked up a source like a dvd player and also during watching tv channel?.if so, locate the t-con board which is mounted covered with metal shield. tried first with re seating the LVDS cable connected to the board to fix loose connection, remove and then re attached to the connector terminal.hope this can help good luck.
Sep 07, 2012 | Samsung Televison & Video
Screen covered with wavy lines what can I do ?
if you are technical then open the monitor and see the primary filter big high voltage capacitor is expanded replace it problem will definatly solved
Mar 09, 2010 | Computers & Internet
Monitor has dark wavy lines on edges
Hi...there,
Well... sure it fixable, but it is going to cost you a bundles... Since you own this monitor for about 10 yrs. It's time for you to give yourself a new LCD monitor for the Holidays... :) Have nice day!
Oct 13, 2008 | HP Computers & Internet
Screen is distorted and has wavy line across.
46" Samsung LCD, screen is distorted and has wavy lines across the screen.
Sep 26, 2008 | Samsung Televison & Video
Wavy lines across the digital screen of DSC-V1
Can u mail me 1 photo at welcomejee@yahoo.com to understand what exactly happening with your camera?
May 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Panasonic PT-51HX41 51" Rear Projection Television Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
