Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Replacing coil pack need to know space from mag
Need to how much space is supposed to be between coil and mag
    President:
  • 2,220 Answers
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 23, 2010
Coil pack wiring
hi its called a coil pack or you can get a coil kit. it sounds like you just need the coil leads if the wire is snapped
Apr 02, 2014 | 2005 Ford Focus
Jeep 3.7 cylenders 2 & 4 not firing
3.7 V6, mileage?
most likely the HV wires bad.
then bad coil pack.
did you check spark directly at the coil pack?
i use 2 known good HV wires to do that and 2 good test spark plugs.
both plugs grounded to engine (shell)
that is how you test any wasted spark coil pack. 3 coil pack.
if that fails the FSM shows, unplugging it and check the coil resistances. if wrong the pack is bad,
keep in mind the res. can read ok and coil be bad ,due to internal insulation break down (internal shorts)
if thats ok. the resistance , make sure the wires are not (primary)
to the coil (the low voltage connnector)
if that is ok, its mostly likely a bad coil, (pray not bad PCM)
if tool-less? start with cheap parts , work to expensive. (guessing)
now wasted spark 101.
if one line opens , both spark plugs die. no spark
the wasted spark is wired in SERIES. ( like Christmas lights)
the magic cuts cost of 6 coil\'s.
so if the HV wires are say, cheap , carbon wire and open
you lose, both spark plugs. use MAG wire and end this issues.
get some nice NGK mag wire or Bosch Mag wires.
you can see i hate carbon wire. for good causes.
(carbon string wire)
mag wires is real wire that is coil spun and is inductive. it
has the correct impedance but is not a resistor its and inductor.
and lasts the longest , and worth every penny.
Mar 29, 2014 | 2006 Jeep Liberty
Number one cyl on coil pack not firing, all others are, codes reads misfire on 1 cyl should i replace the coil pack and how do you test the pack
Check the spark plug first. then if the plug is good you wil need a digital ohm meter to test the coil pack. if you need to know how to remove the coil pack let me know, to test put on ohms should not have more than 2 1/2 ohms restance betweent coil lead to coil connector. If you test the coil pack on both sides of the pack and get a reading then the coil is bad, if it does not read then you haave a bad fireing plate diode.
Mar 12, 2010 | Ford Explorer Cars & Trucks
Coil pack keeps craking
The engine computer is supposed to drive sections of the coil pack in pulses. If a defect in the computer caused current to flow continuously, it would overheat and crack the coil case. Rent a scanner, read any code(s), and pursue to repairs. Replacement of the computer is likely. If so, remove the battery--the computer is bolted to the inner fender panel with several long sheet metal screws. Remove two large plugs from it's case and install the new one in reverse order. The dealer will need the number off of the old unit for proper replacement. You might be able to find one in a wrecking yard for half price. A reputable company will guarantee their parts for 90 days. You will likely need a fresh coil pack too. Hope this gets you running. We put nearly 300,000 miles on '96 Dodge Caravan, but had to replace the transmission @ 120,000.
Nov 17, 2009 | 1996 Plymouth Grand Voyager
Replace Coil Pack on 2008 Mazda MPV
it sounds like the coil pack is bad so go ahead and replace the pack. that should fix your problem
Jun 09, 2009 | 2000 Mazda MPV
There is no spark
I am unsure if your bike uses a coil or CID pack for the spark but whichever it has is most likely the cause. also if you have a kill switch then I would disconnect the wiring to make sure the switch is not grounding out the spark.
Jan 04, 2009 | 2006 Yamaha DT 125 X
Wont start
I know this may sound simple and dumb, but have you checked your ground wire?
Jun 12, 2008 | 1993 Dodge Caravan
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
199 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
