Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Constant flashing red light on my WD-52525 mitsubishi tv
    President:
  • Mitsubishi Master
  • 1,619 Answers
Replace bulb, clean all vents and cooling fans of dust.
Posted on Apr 22, 2010
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Apr 08, 2013 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Replaced bulb in Mitsubishi WD-52525 and it still does not work
What does not work? Does the green light flash or light at all? Can you "manually" turn on the tv? If the light is RED...the replacement was either installed incorrectly (or is not plugged in correctly to the contacts at the rear) or is the wrong bulb. Be sure the door to the front of the bulb in on as there is a micro-switch at the lower right that MUST be engaged.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Wd-52525 HDTV Stutis light constant red
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Shuts down
convergence amp IC's i would start with.
Dec 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Here is the link to the manual if you need it; http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf page 97 states that the lamp is the problem -(the flashing green just means startup - page 11) 14 months sounds about right for a new lamp if you use it a lot - that would be an average of 5&1/2 hours a day if the lamp went to 4000 hrs - although these lamps are more dependable than normal lamps, they can still fail anytime especially if they have been touched on the glass by accident while installing or cleaning, or if the tv is often switched on and off. The fact that there was no message on screen may mean that the lamp has not gone past the warning trigger number of hours - sorry i haven't found what that value is. page 95&96 gives all instructions how to replace lamps and where to get spares - if the price seems bad then search around - prices often vary a lot on these lamps. It is a little disappointing that mitsubishi where not able to diagnose this - please let them know that their technical service is poor in the hope that they try harder. I hope this helps :) Hope this helps :)
Mar 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
