Question about Kirby G5 Bagged Upright Vacuum
The belt keeps coming off
I bought a new roller and now every time I use the vac the belt slips off after a few minutes
reddevil6
  • 1673 Answers
SOURCE: New Eureka vacuum cleaner belt keeps slipping off
You may have a bad brush roll, part #61250-1, or the base itself has a problem and isn't letting the brush roll sit straight so it can be in alignment.
Posted on Jan 15, 2008
reddevil6
  • 1673 Answers
SOURCE: Oreck belts keep coming off
If the pulley on the brush roll is worn, then I would replace the brushroll. Look at the ends where the brush roll sits in to make sure the casing hasn't over heated and not holding the brush in place. Also make sure the motor is shifting and causing the belt to come off. Another is if you are catching a rug or towel, that also will cause the belt to come off. I am assuming you using a new belt and not a worn one. After only a short time, belts stretch and need to be replaced.
Posted on Jan 22, 2008
VacuumRepair
  • 438 Answers
SOURCE: sweeper belt
Greetings from GoVacuum.com,
Have you replaced the belt with a new one yet? You may want to try replacing the belt, as with flat belts like the Fantom Thunder, they do stretch out 4 -5 inches after time. We in fact recommended replacing a flat belt every year, even if the belt doesn't break, because of the stretching. I think what may have happened, is that your belt is stretched to the point where it will not stay on the pulley as soon as there is any tension (putting the brushes on carpeting), which will cause the belt just to slip off.
You should be able to replace the belt (very inexpensive, we sell Fantom belt for $2) and this should take care of the problem. When you replace the belt, you should also take the roller brush apart and remove any hair, or thread that may be wrapped around the bearings. You should be able to remove the bearing cap by pulling them, or holding one end, and unscrewing the other.
I'd even be willing to send you a free Fantom Thunder belt, if you'd be so kind to vote Fixya for this answer :-) Just send me an email with your name, address, and the exact model number (located on the back of the machine, or the bottom of it) of your vacuum, and vote Fixya, I'll immediately ship you the belt for free!
Please let me know if you have any other questions I can help you with.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
1-866-468-2288
Posted on Oct 13, 2008
freetek
  • 5568 Answers
SOURCE: rollers not spining on my kenmore canister vac.
Particles of the failed belt may be  trapped in the bearings which, if I remember right, aren't very well protected.
I'd remove the rollers, slide the bearings off (if they do slide off) and blow them out with a compressor or saturate them with WD-40 and turn manually until they are free again.
Posted on Jan 15, 2009
  • 12 Answers
SOURCE: Kenmore Canister Vac, Progressive, 25512
Take a flat head screw driver and pry the end cap off. It will come off. You might have some string or hair around it causing it to not turn.
Posted on Jan 31, 2009
When using, smells like vacuum is burning. This is without the powerless attached. What do I need to do?
It is most likely the belt. The belts stretch out over time and start slipping. When they slip they burn. Also check to make sure nothing is keeping the roller brush from spinning.
Mar 05, 2016 | Rainbow Vac Cleaner E, E2 Series Electric...
Belt keeps coming off- Dirt Devil Breeze Cyclonic Bagless Upright Vacuum
Turn it upside down and switch on the power briefly to see what happens to the belt while running. Some vacuum cleaners have a wire guide of some sort to keep the belt running true, but yours may not have it. The end of the brush roller that connects to the belt could be worn uevenly, causing the belt to ride off the motor shaft. The motor shaft might not be parallel to the brush roller.
Jan 18, 2014 | Vacuums
I HAD MY DC17 VAC FOR 3 YRS NOW NO PROBLEMS AT ALL, I REGULARLY CLEAN THE FILTER LIKE IT SAYS BUT LATELY I'VE NOTICE THAT THERE SEEMS TO BE A LOT MORE COLLECTION ON THE TOP OF THE FILTER WHEN I'M DONE...
The vac is over heating. First, you should try a new filter. Also, keep in mind that after cleaning the filter, make sure that it fully dries. Using a wet or damp filter clogs it quickly. Second, turn the vac upside down and make sure that the roller is fully cleaned and free of hairs and strings. Afterwards, with the vac upside down, quickly power on and make sure that the roller spins and listen carefully for noise at the roller. There may be something stuck inside. If it doesn't spin, verify that the belt has not slipped off or broken.
Good luck.
Sep 27, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I believe there is something wrong with the roller, could be the barrings or the end caps are warped. Try this, take the roller out and with each hand on each end hold the roller and try to spin the roller with your thumb. If it does not spin freely the problem is the roller.
Nov 20, 2009 | Dirt Devil Featherlite Bagless Vacuum...
New noise when vac is run
mine was allowing the roller/beater bar to hit the cover as it turned take the cover back off and ensure the beater is in the right place then that the cover is locked in the right place then you can spin it by hand (power cord unplugged of course) and make sure it is clearing everything. BTW, the belt has to be stretched to get the beater bar in place like on most vac.s
Jan 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt Keeps slipping off shaft
If this is a new belt that keeps coming off, then if not catching something in the roller like a scatter rug, etc then the belt isn't tracking true. The pulley may have come loose for one thing, something has to be off to have the belt come off. Does it come off almost right away, or after some uasge?
Sep 27, 2008 | Hoover U6434-900 Bagged Upright Vacuum
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Jan 22, 2008 | Kirby G5 Bagged Upright Vacuum
Jan 07, 2008 | Vacuums
Kirby G5 Bagged Upright Vacuum Logo
35 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
