Question about Brother MFC 210C All-In-One InkJet Printer
Can you rechive and old fax that was sent 1 week back
I am trying to retrieve a fax from the memory that was sent to me a couple weeks ago, is this possible?
Hi there!
It is possible if the fax storage of your fax machine is on. To check if its in press Menu 2 5 1, the lcd should show fax storage. and to print the fax press Menu, 2 5 3 to print the stored fax.
If the lcd shows off when you press Menu 2 5 1 there is no way to print that fax.
Hope this helps. Rate if it works. Thanks
Mar 31, 2011 | Brother MFC-8460N All-In-One Printer
I need to retrieve the image of a fax that I sent
In the Fax reports menu, you can select the fax log and it willl have the number you sent to, but the image is gone as soon as you fax it.
Jul 02, 2009 | Office Equipment & Supplies
Hp 640 cant send or receive fax(NO ANSWER FROM REMOTE FAX
Since the fax machine is about 4 weeks old, why not give it back to HP? Warranty still covers it.
May 22, 2009 | Office Equipment & Supplies
Retrieving old fax transmissions
Usually the journal only holds the last 50 sends / receptions.
Feb 02, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Restoring sent and received faxes to fax logs
That's not the way to backup your logs. You copied only the fax images, and not the logs to go with them. This is a common error that is made quite often. Unless you have the original log structure, your data (logs) that link to the actual fax images (fxds, fxrs, etc.) are lost.
Troubleshooting WinFax suggestion:
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Jan 02, 2009 | Symantec WinFax Pro for PC
Need verification of fax sent from about 1 week ago
hello sir,
well sir cheek your cable that is concocted to the fax from telephone
maybe its crashed are distortion in line,
coz fax is not do this with out any big problem
Dec 17, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
FAX back
Do you mean to get the paper document back out of the machine? If it doesn't feed out automatically, it may need to be repaired.
If you mean that you want confirmation that a fax was sent, you can turn on the TX (Transmit) REPORT. This will print out the first page of a fax sent successfully.
1. Press the Additional Functions button.
2. Use the arrows to select FAX SETTINGS. Press the Set button.
3. Use the arrows to select REPORT SETTINGS. Press Set.
4. Use the arrows to select TX REPORT. Press Set.
5. Use the arrows to select OUTPUT YES. Press Set.
6. Press the Stop/Reset button.
The machine will automatically print an Activity Report after every 20 faxes (sent or received). If you want an Activity Report at any time:
1. Press the Function button.
2. Press Report button (number 03 on the left side of the keypad)
3. Use the arrows to select ACTIVITY REPORT.
4. Press the Set button.
Apr 17, 2008 | Canon PC-1080F Plain Paper Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
22 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
