Question about HP Photosmart C7180 All-In-One InkJet Printer
HP Photosmart c7200 magenta not printing - HP Photosmart C7180 All-In-One InkJet Printer
Riztech
  • 731 Answers
SOURCE: I just purchased an HP
Hi
If the printer is out of the Box, don not try any other ink cartridges, becoz you must use the HOST ink cartridges that is shipped with the printer for the first time.It seems that it is problem with Host ink cartridge.
You can check the cartridge whether its a Host ink cartridge or normal one by looking at the serial number.If Serial number starts with C9, it Host; if it starts with C8 its normal one.
Only HP can replace it , none of the store sells Host ink cartridges, they sell the replacement ones.
You can either call HP tech support or, return the printer to staples.
Thank You
Rizwan
rizwan84tx@gmail.com
Posted on Dec 07, 2008
SOURCE: Have HP Photosmart C7200 and
I had the same problem and just found the solution.
Solution one: Make sure that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. If it is running, the DIM icon (c01404188.gif ) is present in the notification area. The notification area is located in the lower-right corner of the computer by the clock. Figure 1: Notification area c01404189.gif If the DIM icon is in the system tray, you do not need to complete this procedure. Skip to the next solution. Follow these steps to set the computer to run the DIM.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ).
  2. In the Start Search text box, type msconfig , and then press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window appears.
  4. Click the Startup tab.
  5. Select the HP Digital Imaging Monitor check box. If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Reinstall the software to resolve this issue.
  6. Click Apply , and then click Close .
  7. Click Yes to restart the computer.
  8. Attempt the scan again.
Posted on Mar 18, 2009
PeteG0429
  • 34 Answers
SOURCE: C7200 prints blank page between each printed page
Here's a solution. Hope it helped!
Posted on Apr 02, 2009
You need to have the disk and reinstall the printer delet all the printers and fax that you have and use the disk to reinstall it fixed my issue or use the HP online chat to help with the issue.
Posted on Apr 16, 2009
  • 72 Answers
SOURCE: My HP Photosmart C7200 has an error message that
'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' Error Message Displays on the Control Panel
YOU CAN ALSO GO TO THE FOLLOWING LINK:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&lc=en&dlc=en&cc=us&lang=en&product=3382185
Have a good day,
Posted on Jun 25, 2009
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3110 does not print magenta or light magenta
i think you need to download a perfect drivers
i hpe i can solve your problem
Sep 02, 2009 | HP PhotoSmart 7960 InkJet Printer
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
How to do multiple copies on HP Photosmart C7200 All-in-One series
Instead of pressing the shortcut to print, go to file>print> and type in the amount of copies that you require then press print.
Nov 24, 2008 | HP Office Equipment & Supplies
My hp photosmart d6160 printer is not printing black. I have replaced the black cartridge with virgin hp ink. What can I do?
my hp photosmart d6160 printer is not printing magenta.
I have replaced the magenta cartridge with virgin hp ink.
What can I do?
Oct 07, 2008 | Office Equipment & Supplies
Prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Aug 01, 2008 | HP Photosmart C7280 Laser Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
478 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
