Question about PfaFF Sewing Machines
Pfaff tipmatic 6152 presser foot won't go up and
Pfaff tipmatic 6152 sewing machine - presser foot won't go up and down.
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
SOURCE: presser foot
to drop the bottom feed open the bobbin area--there may be a switch to the right
Posted on Mar 09, 2010
  • 255 Answers
SOURCE: Are pfaff 1475cd sewing feet compatible with pfaff 1151 machine
Hi. Some Pfaff machines have something called an "IDT" which looks rather like a small, black walking foot behind the pressure foot, to help feed the fabric evenly. Pfaff machines with this IDT need "IDT" pressure feet. (I can't find a listing of which machines have this and which don't, so you'll have to look at your machines or check your manuals.) If both machines have the IDT, then the feet are compatible. If neither has the IDT, then the feet are also compatible.
Hope this helps!
Happy Sewing,
Robbie
Posted on Mar 15, 2010
RichSew
  • 194 Answers
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Posted on May 27, 2010
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
Re: Pfaff sewing machine, How do I use the zipper foot attachment?
It really depends on what your zipper foot looks like. There are several that can be used with the Pfaff machines.
Pfaff Zipper Foot 4
Pfaff 1067 zipper foot instruction Google Search
Jul 08, 2017 | PfaFF Sewing Machines
The presser foot on my Pfaff Tipmatic 6122 will not stay down, so the fabric will not feed.
It sounds like the pressed bar is sticking and will not push down completely and is difficult to lift. I have come across them many times on the older pfaffs. Unfortunately that is not sometime that can be fixed at home. It is caused by the lube going bad inside the pressed bar that lubbricates the spring that is inside the pressed bar. Find a pfaff dealer that knows about older pfaffs and they should be able to help.
Nov 15, 2016 | PfaFF Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
I have a pfaff 6100 tipmatic the presser foot lowers but has no pressure when I leave it in the lowered position it will eventualy get presure, it has oil. help my local sewing repair man has tried bu
This is common with older pfaff sewing machines. Remove the old oil it has hardened into a lacquer like material. Clean the area with rubbing alcohol. lubricate work the foot up and down. repeat.... repeat..... until it loosens up.
Oct 08, 2014 | Sewing Machines
Can't get my presser foot to fall down when I let go of the lifter on my Pfaff 6085 sewing machine
Sounds as if the spring for the presser bar is broken OR the presser bar is dirty and needs cleaned and oiled.
Feb 25, 2013 | PfaFF Sewing Machines
Dec 31, 2008 | PfaFF Tiptronic 2030
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
I'm looking for a manual...
I have the manuel you need by copywrite laws prevent me from copying it for you. I do however have and address and telephone number that you might be able to purchase one from them.
Pfaff SALES AND MARKETING
610 WINTERS AVE.
PARAMUS, N.J. 07652
201-272-7211
PFAFF SALES AND MARKETING
17852 GOTHARD ST
HUNTINGTON BEACH, CA 92647
714-375-5665
And yes yours is called 6152 tipmatic. Heidi
Dec 25, 2008 | Sewing Machines
Sewing Machines Logo
233 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
