Question about Biostar NF325-A7 Motherboard
The motherboard comes on when the power suppy is switched on. even with no ram or hard disk it turns on and gives no beeps.
  • linstromm Apr 22, 2010
    ive tried two diffrent power supplies.
    President:
  • 1,768 Answers
This issue is a possible mother board going bad or a power supply switch that is "open and needs replacement. I tend to go towards the latter. Replace the power supply.
Posted on Apr 22, 2010
  • Harleen Nash Apr 23, 2010
    the power switch may be defective (open).
  • Steve Jul 08, 2011
    Check your BIOS. It may be set to "boot when AC power is on". Most new mobos can be set to either "stay off " or "stay on"
Acer aspire z5700 wont come on
1 long, 1 short beep : System board problem
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive I SATA
Nov 22, 2012 | Acer Aspire Z5700 (PWSDC02010) 23 in PC...
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
When powering the laptop, it has power for about 4 seconds and then turns off. The screen doesn't come on or doesn't even start the booting process. What would cause this to happen?
Are you using battery power or is it connected to your power outlet (AC = alternating current)?
If you're on battery make sure that the there is enough charge for the battery to turn on your computer, you can also try to remove the battery and plug it directly to AC, otherwise your laptop may have a bad hardware (mobo, RAM, Videocard, etc) does it give you any beeping sound when you turn it on?
(If you feel confident enough)
You can try to remove the RAM, Hard disk drive, wireless card on the back of your laptop then try turning the computer on and check if it will give you any beeping noise. Now put the parts you have removed back to the computer one by one while turning on the computer before putting the next one in. (Example: put the RAM in turn the computer on, turn it off again then put the Hard disk drive in and so goes the other parts)
If the above steps does not work. You can try calling Sony so they can check on the motherboard and the video card of your laptop.
Hope this helps!
Apr 12, 2011 | Toshiba Satellite X200-AA3 Notebook
No display, i have already change my ram, processor, power supply but no result if i pull my ram replay ram beep from motherboard
no display is basically ram issue but condition that mother give u beep noise,
refix RAM proprely, chaque SMPS , PROCCESSOR,HARD DISK, Fixed togethar again ok resolve issue.
Mar 17, 2010 | Intel 845GEBV2 Motherboard
Computer will not reboot, I have power, when I press the switch I get a yellow light under the hard disk indicator and the E-switch will not turn blue, stay off all the time. I have the impression that I...
Test your motherboard first - unplug everything (except at least some of the RAM) and see if it boots up. You should at least get a beeping sound.
If that works, check the RAM piece by piece - you can find a free program called MemTest (or Memtest86) online with will run from the boot menu, so it will execute and test all your RAM chips before the hard drive even starts up. If that all checks out fine, add in graphics card, hard drive, etc until you find the component which breaks it.
Mar 09, 2010 | Computers & Internet
Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Mar 03, 2009 | Toshiba Tecra M2-S730 Notebook
Not everything powers up when I turn on my disassembled computer
remove first the power suppy. if it is 24pin power suppy, shorten pin 15/16. that is the black and green,
if the fan of power supply rotates, then the P.S. is ok.
then return it to motherboard. check your connection with the motherboard power switch.
good luck
Feb 14, 2009 | Jetway (939AGP-OC) Motherboard
Power problem i think
If there is no beep, even after removing RAM means you have faulty Motherboard and/or faulty Processor.
Try to reconnect CUP also clean the CPU socket on board and try to test without RAM, if you got long beep (RAM missing) then proceed further i.e. add RAM, HDD, CD/DVD etc step by step.
If didn't get any beep try to test with other motherboard/CPU to find which one is faluty.
Please post your feedback.
Thanks and Good Luck
Iqbal
Aug 18, 2008 | EliteGroup K7VZA Motherboard
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Open Questions:
See all Biostar NF325-A7 Motherboard Questions
Biostar NF325-A7 Motherboard Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
