Question about Belkin (F5D7633UK4A) Wireless Router
Internet Connection drop outs on Belkin ADLS2+ modem router
Hi All,
I've been trying, unsuccessfuly, to connect this moden to the net.
Basically the modem has:
power on
LAN
Phone line and wireless, when trying this way.
But the internet light does not come on.
Computer says i'm connected at 100Mbps, but no internet connection.
I've re-set, re-booted, called Belkin. my isp etc.
Planning to go dump this Modem and go elswhere.
Most annoyingly, I have got internet connection, when I only go to the Belkin home page and try and connect from there.
Comments please.
Note this is the Australian issue modem, F5D7633au4A, but the site wouldn't register, so had to use the UK code.
    Sergeant:
    Champion:
  • 427 Answers
Try to call your internet service provider. They should most likely resolve your problem. Or, disconnect everything. Plug the cable wire to the back of your modem. Give it 30 seconds. Plug in the ethernet cord from your router to your modem. Plug in the power adapter to your modem and give it 1-2 minutes to start up. Next, Plug the power to your router. Give about 1 minute. Go onto your computer and hit the start menu, go to the control panel. Look for internet connection and click on it. Find you internet connection, right click, and hit properties. Click on TCP/IP. Make sure your settings are on automatic. Then try your internet.
Posted on Mar 23, 2008
Wreless devices causing modem to drop out requiring reset to connect to internet. Works fine with belkin wireless adapter. Lg dongle for HDD recorder and Mobile phone both cause problem. Is there any fixes...
You're better off buying a better, new router (one that includes a "Self Healing" feature that will basically reboot the router automatically on a set schedule). Also, try a different brand, Belkin is infamous for making routers that constantly drop connections.
Feb 28, 2011 | Belkin F5D8631-4 Router (F5D8631au4A)
Internet drops out, needs to be reset often. I have wireless N Belkin router, but even the wired connections have internet dropping out. i need to unplug, wait, replug and internet comes back. Why?
It is a problem with your ISP connection. Basically, it has nothing to do with your router or modem. Please report this issue to your ISP immediately and see how they can solve this from their end.
Dec 22, 2009 | Computers & Internet
My Belkin N1 router can't seem to establish connection with the cable modem - the router light flashes and connects but as the internet light flashes it loses the router light again. It is still allowing...
the modem is working fine. the connection might be dropping from the router side.
You can try to upgrade the Firmware of the router.
reduce the MTU on the router. If it is on 1500 the reduce it to 1400.
Click Here from more info about routers
Oct 31, 2009 | Belkin (F5D8231-4) Wireless Router...
Modem light blinking and no internet in the wireless router. but when i run a cable from my modem to my computer, internet works....but when i rund the cable from the modem to the belkin wireless...
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
Apr 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Major issues
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now.
Hope this helps, and good luck!
Apr 16, 2008 | Belkin (F5D8231-4) Wireless Router...
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
No internet connection
tobe honest try to uninstall internet explorer 7
Dec 09, 2007 | Belkin Wireless Cable/DSL Gateway Router
Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7633UK4A) Wireless Router Logo
145 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
