Question about Epson Stylus CX9400Fax InkJet Photo Printer
Is it possible to make my epson cx9400fax printer connect wireless? It has something that looks like a usb port
    Scholar:
  • 154 Answers
Yes, it requires you to purchase a device to connect to your printer with a usb cable that allows it to connect to the wifi network, here is a link to details on the ones I use myself, exptremly easy to set up and quite cheap:
http://www.belkin.com/iwcatproductpage.process?product_id=354892
Posted on Jun 22, 2010
Interfacing EPSON Stylus 440 to Pentium Dual Core CPU
Current printers no longer have the parallel port and neither do computers. The printer can be connected through USB, Ethernet or even Wireless. If the printer has a parallel printer port and none of the other means of communications you should look for an adapter USB-LPT.
Oct 25, 2013 | Epson Stylus Color 440 InkJet Printer
Make Epson Photo RX620 print wirelessly
This model printer has only an USB connection.
It is possible to print wireless by connecting the printer to your computer and sharing your printer on your network that is connected to a wireless router.
OR connecting your printer to a wireless router that has an USB port for connecting a printer.
Aug 04, 2012 | Epson RX620 All-In-One InkJet Photo...
I had a wireless router installed and can no longer fax using CX9400FAX series. Receive communication error ''no dial tone''. There is a phone line from the phone to printer and from printer to wall jack....
I too was having the same problem. We too have a wireless router hooked up. However, that had nothing to do with the problem. Our problem was that the top phone line port on the fax machine should run to the phone jax in the wall. The bottom phone line port on the machine should run to the phone. We had them switched around.
I hope this helps.
Dec 22, 2009 | Epson Stylus CX9400Fax InkJet Photo...
I have an Epson CX9400Fax all in one printer, fax, scanner. Yesterday it quit accepting print commands from the computer. It still copies, scans and saves scan files from the unit to the computer so I am...
Reinstalling the software is great, but did you first remove your printer usb cable, uninstall the printer and then re-install your software?
If not, do those 3 steps in that order and try printing again.
Best wishes,
Graemevm
Dec 17, 2009 | Epson Stylus CX9400Fax InkJet Photo...
How do I enlarge the print on an Epson Stylus CX9400 fax series?
the printing wizard it has the size choice ...but the actual size its established by the limitations of the printer ..anyway all documents may be re-sized in the computer and than printed...even in pieces and reattached after if the printer supports only A4 paper maximum
Sep 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Epson CX9400Fax Error Message
Sounds like a software issue. Reinstall or call Epson tech support.
May 18, 2009 | Epson Stylus CX9400 Photo Printer
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
CX9400 Windows 98???
Unfortunately, Windows 95, 98, and Me are not supported with this printer.
Listed below are the system requirements for your printer.
Windows Requirements
- A Microsoft Windows compatible PC with an 800MHz processor (1GHz or faster processor recommended)
- Microsoft Windows 2000, Windows XP, Windows XP Professional x64 Edition, or Windows Vista
- 256MB RAM for Windows 2000, Windows XP, and Windows XP Professional x64 Edition (512MB recommended) - 512MB RAM for Windows Vista (1GB recommended)
- 300MB free hard disk space (550MB recommended)
- 4x or faster CD-ROM drive for installing the software
- A Windows-compliant USB port and shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
Macintosh Requirements
- An Apple Macintosh with a PowerPC or Intel processor
- Macintosh OS X 10.2.8, 10.3.9 to 10.4.x or later
- 256MB RAM (512MB recommended)
- A USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
May 25, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400Fax InkJet Photo Printer Logo
212 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
