Question about Boating
I have a 2007 e tec 95 hp outboard. I have metal shavings inside my prop. What can this be from?
    Sergeant:
  • 352 Answers
SOUNDS LIKE LOWER END GEARING AND OR BEARING DAMAGE
Posted on Sep 12, 2012
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
They exhaust out through the prop, could be the start of some internal engine problems
Posted on Apr 25, 2010
Evinrude E-tec 115 hp 2007 model No power to engine or hydraulics
Sounds like a fuse has blown, look behind your dash panel.
Mar 15, 2017 | HP Boating
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
What would be the cause of metal shavings in my fuel pump
The pump is a vane pump and it is probably carving itself up inside hence the shavings. Really the only place they can come from if you think about it.
Sep 11, 2014 | 2007 Toyota RAV4 Limited
Replace a propeller bush on a 1998 15 hp outboard
if its a through prop exhaust then need to use a press to get it out and back in ! most marine workshops or outboard breakers will have a supply of sec hand props and pos exchange yours against a new one !
Jan 02, 2014 | Boating
Have 2007 yamaha 115 saltwater series, just bought, planned once and then didnt plane, was told its prop bush slipping, can you explain?
The splined hub on the prop is not solid , there is a rubber or plastic sacrificial piece between the outer and inner portions of the hub. Designed to slip if you hit rocks or run over a rope so you dont ruin your drive or motor, just a prop.
Sep 03, 2012 | Clymer Marine Maintenance and Repair...
I have a 4o hp outboard marinier and when u give it about half throtal or more it acts like its slipping,
It is most likely a damaged prop. If the gear shift handle is steady while it is slipping, Your prop needs to go to the shop for a re hub. Take a punch and mark the center of the prop (the hub) ,then mark the blade of the prop in alignment. Try it out and see if the marks still line up. If they have moved- the prop is bad.
Aug 29, 2010 | Raymarine Linear Feedback Unit For...
Plastic metal shavings inside printer
I had a similar problem on an hp-3052. I was getting pieces of plastic that were grey and yellow stuck to my pages and all inside the printer then papaer stared jamming. The problem was the fuser sleve which can be picked up on ebay fairly cheap. The bigger problem is installing the sleve over the fuser. I tried the repair my self and broke the fuser assembly. It's a cheap part but a pro should do the install this is definately not a diy fix.
Sep 26, 2009 | HP LaserJet 1020 Printer
60 hp Manier running great when losted all power ,motor runing
take your prop off and look at the hub you have a spun hub or the wrong size prop and it is cavitating or prop washing
Jun 28, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
