I BOUGHT A USED RICOH AFICIO COLOR 3006 COPIER FROM THE UNIVERSITY OF GEORGIA YESTERDAY. WHEN I TURN THE COPIER ON, I GET AN ERROR CODE SC456. WHAT DOES IT MEAN AND HOW DO I FIX IT?
    Sniper:
  • 58 Answers
SC456 = Paper transfer unit position error.
Open the fron cover, make sure that all levers are in the correct position, and make sure that all covers (Sides and front) are closed.
If the error persists, it means that that there is a dirty/faulty sensor, and you should call out the repairman to have a look.
Posted on Mar 23, 2008
  • 1,512 Answers
Hi there
The error code 456 - Paper transfer unit position error.
If you cannot find any jammed paper in the unit, you may need a Ricoh service guy to give it just that. A good service
regards
Graeme
I have problem with Aficio 220 Ricoh Japan machine and fault is like this SC541 (Fusing thermistor open A level) please help me. my email is auk270@gmail.com
Verify your fusing lamp or thermofuse and replace it if necessary
If your circuit is correct, replace the power supply unit
Don't forget reset code :
Enter SP 5-810 (SC code
reset) and select "1". Then hold
down the Photo mode key and
the 7 key at the same time for
at least 3 seconds (this does
not require the main switch to
be turned off and on).
Jul 07, 2011 | Ricoh Aficio Colour 3006 Color Copier
SC387 error code on Ricoh
SC387 Drum potential
error
Cause
· Uneven charge
· Worn drum
· Defective potential
sensor
Try the following
1. Clean the charge corona unit or replace the charge
corona wire and grid plate.
2. Reinstall the drum.
3. Replace the drum if necessary.
4. Replace the potential sensor.
Let me know if you need any more assistance
May 08, 2010 | Ricoh Aficio Colour 3006 Color Copier
Error sc 452 shown on my aficio 452 color copier how to rectified
sc 452 is a thermistor error code for the fusing unit of the copier. Try pressing these buttons in sequence. (yellow key) (1).(0).(7) (red Clear/stop key) and hold the red key down for 5 seconds. When the 3 or 4 boxs appear, turn your copier on and off with the main power switch. If the error code comes back then contact the seller of your copier and ask for technical service.
Oct 12, 2009 | Ricoh Aficio Colour 3006 Color Copier
Ricoh CL 7000 down due to an SC-685
Do you have the copier feature option installed?
It is most likely just a loose connection on the interface between the main printer unit and scanner section. Turn off main power (red button), and re-seat the connector.
Please let me know and rate solution :)
Apr 17, 2009 | Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio 3006 error sc452
The SC 326 is -- 2nd laser synchronization error. Meaning, the 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Basically your polygonal mirror motor unit is bad and needs to be replaced. You can replace the whole laser unit but that is expensive. When you replace the PMM unit, do so in a still air area -- as to not get anything in the unit. When you get the PMM unit -- contact me and I can walk you through the steps to replace.
The SC 452 is --- Transfer Belt Mark Detection Error. Once you fix the SC 326 error this one should be fixed also.
Jul 17, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Apr 24, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
Error code SC510- suggests reset but comes on again.
Make sure the paper is loaded properly in the trays. You can try using a different tray or not loading as much paper in the trouble tray.
Jun 15, 2007 | Ricoh Aficio Colour 3006 Color Copier
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
