Question about Kenmore 45087 Front Load Washer
Display shows sud - Kenmore 45087 Front Load Washer
  • 5,911 Answers
"SUD" is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Posted on Apr 22, 2010
What does it mean when SD is showing on the display
The Sd (5d) error code is displayed on this washer when the machine control board detects a suds-lock condition by analyzing the drag on the washer basket. It will be displayed while the control runs a mini-clean out cycle. If this clean out cycle is unable to remove the excessive suds and correct the condition, then the cycle will end and Sd will flash in the display.
Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity in your washer. If you detect excessive suds in the washer, this likely caused your problem.
Another cause could be a toy or other item under the washer that would cause friction on the drive mechanism. If you do not see excessive suds, check for this type of problem under the washer.
Jan 19, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing ?Sud? error code on...
The error Sud is shown on the display due to Overdose of Detergent detected during the Wash Cycle in the washing machine.
In this problem check the MCU in the washing machine. The motor control unit senses a suds lock. Also check the Drain pump for any blockage or the heavy load in the washing machine. or over quantity of detergent is added to the machine and that is got blocked.
This will Help. Good Luck.
on Mar 11, 2010 | Washing Machines
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have an HE 5T Steam Front Loading Automatic Washer. It is showing Sud indication, nothing seems like happening and after few minutes it will show F35. What does it mean?
Hello again,
I found your manual. If you like to get it, go HERE. This is what it says about "SUDS" action:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Near the bottom of the troubleshooting page, it gives this for errors:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
It doesn't specifically state what "F35" is, so I can only suggest these steps, and see if this solves your problem. If it doesn't I would be inclined to believe that there is a problem with a part, which would probably be serviceable by a tech from Sears or their partner service company.
Hope this clears it up for you.
Please rate and comment. Thank You
Joe
Sep 02, 2011 | Kenmore Washing Machines
My washer stops and suds flash on the display
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
Possible causes/procedure:
If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
Use your tech sheet for diagnostics it is behind that panel the Handy Hippy showed you how to take loose (see above link) Use this MANUAL for Duet sport as a guide for repairs
Thanks for using fixYa
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Display showing alternately Fu and d making a bleeping noise wont
Sure it's not SUD ?? which means you may be using the wrong detergent for a front loader. Use HE detergent.. it has no suds.
Rinse the machine out by using the quick or express wash cycle with cold water and two cups of vinegar in the soap dispenser.
Once those suds are gone, it may take a while, ie a couple of vinegar rinses, it should work just fine.
Aug 22, 2009 | Washing Machines
Kenmore model 45872400 won't spin,and screen
current draw on the drive motor. If “Sud” is displayed a potential Suds
Jun 09, 2009 | Kenmore 24032\24036 Top Load Washer
Suds on display screen
run washer with no load or detergent to be sure no suds remain use HE detergent only..if you are suds is not an issue remove lower panel and clean pump ..turn white knob counter clockwise ..electronics can get confused sometimes too
Jul 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 45087 Front Load Washer Logo
66 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
